20 Most Recent KitchenAid Architect Series KEBC208KSS Electric Double Oven Questions & Answers
Good morning, the fan noise is probably the cooling fan in the control compartment. With an electric oven, it could be a resettable thermostat that tripped and needs to be reset. Or it could be a bad heating element. Display will display lot if it can't bring the oven temp up. Hope that helps.
KitchenAid... | Answered on Feb 11, 2018
Check power connections may have loose return ground loose beaker in fuse box from home or over heat issue
KitchenAid... | Answered on Feb 02, 2017
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
KitchenAid... | Answered on Sep 28, 2016
Click HERE for the service manual and refer page no. 21-22
This will solve your problem.
Goodluck,
Please don't forget to rate me as fixya..
KitchenAid... | Answered on Jun 27, 2015
If this noise is happening when the oven is off as well, it is a problem with the cooling fan that draws hot air out of the oven. These fans go bad after a few years and need to be replaced or repaired. Not a difficult fix, but the oven unit needs to be removed fromm the wall cabinet which is a two person job.
There are several web sites that sell the part. Try www.appliancepartspros.com or www.partselect.com.
The part number is either PS992856 or PS2348323 so I would call one of these companies and ask for help on the exact part you need.
KitchenAid... | Answered on Nov 20, 2013
Absolutly could of course be the EOC (electronic oven control) since it does control both the upper and lower over. Sorry for your luck but just because a part has a high failure rate that manufacture isnt required ti issue a recall as long as thier isnt a saftey issue such as potential fire or what have ye
KitchenAid... | Answered on Jul 23, 2011
IT HAS A SHORT IN THE WALL WERE U INSERT THE PROBE
KitchenAid... | Answered on Dec 26, 2010
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^^^^^
KitchenAid... | Answered on Oct 01, 2010
KitchenAid Architect Series KEBC208KSS Electric Double Oven Logo
44 questions posted
Top KitchenAid Ovens Experts
Michael Thomas
Michael Thomas
jdthefixer
Marvin
Marvin
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
View Most Popular
KitchenAid Ovens
  • KitchenAid Ovens
Most Popular Question
clean roof akl 828 1x
  • Ovens
