20 Most Recent KitchenAid KEBC107 Electric Single Oven Questions & Answers
9answers
Superba convection oven probe display problem
I had a similar problem today with my KitchenAid Superba wall convection oven (2002 model). I was roasting tomatoes at 225 degrees F for 3 or 4 hours when the control pad changed and showed that the probe was in use (never have I used it and had to look for it). I, too, tried to plug in the probe and take it out, but nothing changed. My worry was that I could no longer use the timed bake function. After trying to reset by turning off the oven at the breaker, with no change, I turned on the oven to 400 F and left it on for 10 - 15 minutes hoping that the high temperature would dry out whatever moisture that must have gotten in the place where the probe connects. Then I turned it off and just waited. After a half hour or so the control pad cleared and nothing showed (that is what you want when the oven is off!). Everything is back to working now.
12/31/2022 7:37:08 AM • KitchenAid... • Answered on Dec 31, 2022
Error code F5EO
F5
- E0 Door switches do not agree (condition
exists when door switch is closed indicating an open door, and latch switch is
closed indicating a locked door) 1. If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door
    switch to control. If no damage to wires and all connectors okay, proceed to
    step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from
    memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure
    operation is correct.
2. If door not latched:
  2. Check wires and connectors from control to latch switch, then from latch
    step C.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals).
Replace switch if defective.
4. Measure latch switch (unlatch = switch open,
CAUTION - oven light contacts are closed). Replace switch if defective.
5. If
corrections are made in any step, reconnect power to control. Press and hold any
key for 1 minute to clear R failure code from memory. F2 will appear. Press
CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure
remains, disconnect power and replace control.
Note:
Applies to all F5-E... codes.
9/3/2019 10:15:27 PM • KitchenAid... • Answered on Sep 03, 2019
Kitchenaid Superba 27 KEMS376WHO
Go to manualsonline.com. They will ask for make and model of your appliance. Most manuals are free. Give it a try.
7/9/2018 2:02:24 AM • KitchenAid... • Answered on Jul 09, 2018
2answers
Multiple replacement of Microwave door springs
KitchenAid Architect Series KEBC107KSS Electric Single Oven problem error F1E7
7/9/2018 1:55:21 AM • KitchenAid... • Answered on Jul 09, 2018
3answers
Error EO F2
EO-F2
Is a poorly connected keypad ribbon.
Remove the front panel and unplu, then re-insert the keypad ribbon in the control.
8/23/2017 8:19:15 PM • KitchenAid... • Answered on Aug 23, 2017
How to disconnect the oven probe on a kitchenaid superba oven?
un plug from EOC board
2/2/2017 10:06:17 PM • KitchenAid... • Answered on Feb 02, 2017
KERC506HBS3
One thing I've run across is that the heater leads burn off the terminals inside the oven cabinent.
5/9/2014 11:11:14 PM • KitchenAid... • Answered on May 09, 2014
Oven light switch
replace the bulb with an appliance bulb found at any store that sells bulbs
11/18/2013 5:15:54 PM • KitchenAid... • Answered on Nov 18, 2013
3answers
Temperature probe icon persists on the display and
If the probe is not connected, then the actual connector in the oven is faulty. If you don't use the temperature probe, you can take the front control panel off and disconnect the probe connector. I did this 8 years ago
10/4/2013 4:58:18 AM • KitchenAid... • Answered on Oct 04, 2013
manual
KitchenAid KEBC107 Electric Single Oven Logo
164 questions posted
Top KitchenAid Ovens Experts
ZJ Limited
ZJ Limited
vince
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
View Most Popular
KitchenAid Ovens
  • KitchenAid Ovens
Most Popular Question
kitchenaid superba 27 kems376who
  • Ovens
