20 Most Recent
Kohler Cimarron Comfort Height elongated 1.6 gpf toilet with Class Six tech Questions & Answers
BRand new elongated Cimarron shoots water out of bowl durng flush
Is the fill line in the tank loose? Does it just shoot water into the tank itself? I had this issue until I realized the while fill tube is supposed to be pushed into the black cylinder/small plastic tube in the middle of the stopper assembly. After i pushed the line into the tube, the bowl would always only fill a little bit. Now it fills almost a 3rd of the way up the bowl and doesn't bubble during flushes.
Aqua piston toilet keeps running....
Kohler customer service has provided a free seal (yellow) to replace the original seal (red)on the bottom of the Aqua Piston. The yellow seal is a big improvement over the red seal, but the toilet tank still leaks. I am ready to return the toilet to Home Depot.
Kohler k 4436 toilet dose not flush
Went to a Sheraton in Petaluma, CA over the weekend where they have this exact toilet that we also have two of in our home, and damn if the thing didn\'t flush there too. The maintenance guy says they have chronic problems with it.
Water runs intermittently when toilet
Hi aselbst...
Water running is an indicator that the "Ball ****" water inlet device is leaking by, there is no fix to this problem.
You must replace the ball **** to stop the water from leaking,
The ball **** is non-repairable.
You can try to adjust the float to a lower level, sometimes that will work to stop the leak
Please take time to rate me
When I try to flush
You just need to adjust the chain attached to the silver part. Just unhook it and go up maybe 3 links on the chain. This will help it lift up higher when you go to flush it.
