20 Most Recent
KitchenAid KERA205PSS Electric Kitchen Range Questions & Answers
Kitchenaid kera205pss convection oven feature not working
Beth, you either have a failed convection element, part number 9460769, possible bad terminal connection at the element or a failed oven control. A bad element is the most common failure. replacement instructions for a failed heater can be provided.
How do you replace the
unplug the unit,then there are 2 screws where the element mounts to the oven body,remove these carefully and pull back/out to expose the connections,then unscrew the connections or remove the spade lugs that the wires hook up to the element,then just reverse procedure to reinstall element and oven
Replace oven baking element on Kitchen Aid model # KESC300BWH6
It is easy!! After you remove the two screws pull straight out and do so easily, there are two female spade connectors on the element that you'll have to remove. When removing don't pull on the wire itself,pull on the connector. You may have to use pliers.
How to replace bake oven element on kitchen aid
This is a very simple repair. The following link explains how to replace the bake element:
http://www.fixya.com/support/r469407-replacing_bake_or_broil_element_in
If you have not purchased a replacement element yet, the part number is 9755770. The cheapest place I could find the element was appliancepartspros.com for about $54.
NOTE: The element may be slightly mishapened during shipping. If you have to straighten the element to install, use care that you do not crack or break it.
If you have questions about this repair, or if you need additional assistance, please let me know. I hope this helps you.
Probe senser on
try unplugging the oven,then plug it back in or try putting the probe in and take it out,if that don't clear it then you may have a bad board
KitchenAid Stove KERS205TSS 2 light issues.
The issue with the oven display light and the oven light on the KitchenAid Stove KERS205TSS 2 may be related. The problem with the oven display light could be due to a faulty control board or a malfunctioning light switch. The control board may need to be replaced if it is not sending a continuous signal to keep the light on. On the other hand, if the light switch is defective, it may not be able to maintain a connection to keep the light on.
The issue with the oven light staying on could also be due to a faulty light switch. If the switch is stuck in the "on" position, it will not turn off even when the door is closed. This can cause the bulb to burn out prematurely and waste energy. To fix this issue, you may need to replace the light switch.
It is possible that both issues are related and caused by a malfunctioning control board. If this is the case, replacing the control board should fix both problems.
To fix these issues, it is recommended to contact a certified technician or an authorized service center for KitchenAid appliances. They will have the expertise and tools necessary to diagnose and repair the stove safely and effectively.
