20 Most Recent KitchenAid KESC300 Electric Kitchen Range Questions & Answers
Check the burner for continuity with a multi-meter. Post back the results.
KitchenAid... | Answered on Dec 10, 2012
it is the backlit display, i just replaced one lastweek that done the same thing,, you will need to replace it to get the lights to work,, repair clinic.com should have one for your model
KitchenAid... | Answered on Nov 28, 2011
I believe itis in the book under sabbath Mode. On the older ones oyu had to hold off for 5 seconds
KitchenAid... | Answered on Aug 17, 2011
Hello & Welcome to FixYa
There are many things to check for before replacing the oven control board. First thin that needs to be checked is the oven relay (part#30 in this image). If the relay is fine then check the thermostat (part#9 in this image). If everything else tests fine then recommended repair will be replacing the control board. Please get back to me if you have any other questions.
Kevin
KitchenAid... | Answered on Jun 19, 2011
it will be the same way as the four prong except there is no green wire to ground so long as the middle wire goes to the center post of the terminal block and the two outer wires go to the left and right sides of the terminal block everything should be fine.
KitchenAid... | Answered on Mar 03, 2011
I've never heard of that, actually laughing at the fact that he said that. Based on the high temperatures generated from self clean, a lot of components will fail. I always recommend that customers do not use self clean for that reason. I've seen a lot of control boards go bad as a result of self clean. I always recommend just cleaning the oven manually while its still warm. But yeah, i will agree with your electrician.
KitchenAid... | Answered on Feb 21, 2011
Error code F5 is a door latch failure and is displayed due to malfunction of door latch-switch assembly. First try to check the door latch switch, if fine then recommended repair is replacement of door latch-switch mechanism. Please get back to me if you have any other questions.
Kevin
KitchenAid... | Answered on Jan 03, 2011
check to see if you accidently set it to Celsius that is about 550 Fahrenheit and makes sense
KitchenAid... | Answered on Dec 30, 2010
KitchenAid KESC300 Electric Kitchen Range Logo
66 questions posted
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
wp4eld1
Level 1 Expert
gbob59
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Kitchen Ranges
Most Popular Question
wire
  • Kitchen Ranges
