20 Most Recent Kohler 3386-6 Rialto Skylight Round Front Toilet Questions & Answers
8answers
Can't change the toilet seat that broke
If your problem is like mine your toilet seat is loose and swivels when you sit on it. If you try to tighten down the screw it won't tighten. Use instructions above to remove old hardware.
To fix with new hardware
Purchase Hilti brand 3/16" x 2-1/2" Toggler Brand Toggle Bolt (Home Depot sells the kit). Kit comes with 10. You will only need 2. My last repair lasted about 8 years (with new kit = 40 years left or the purchase of a new toilet - whichever comes first). Set comes with 3/16 flat head screws. I recommend purchasing 3/16" 2" round head screws with matching flat washers. Sink Metal Toggler into hole with toggler pointing straight up (it's attached by long plastic legs). As it goes in the hole it opens up. Pull up on the plastic pull rings as tight as you can until the toggler is tight up against the inner porcelain of the bowl (similar to tightening cable ties). Line the seat up with the holes and it's new plastic adapter (that won't slip into the hole courtesy of Hilti). Slide washer underneath round head screw but on top of toilet seat assembly and screw directly into the newly installed toggler which is sunk in bowl/abyss receptacle. Repair should take around 5 minutes.
2/17/2016 12:33:15 AM • Kohler 3386-6... • Answered on Feb 17, 2016
I cannot tighten the toilet seat on my kohler 3386
Give Kohler a call AFTER you read the instructions thoroughly. Good Luck, seriously.
7/29/2014 5:56:42 PM • Kohler 3386-6... • Answered on Jul 29, 2014
Self closing toilet seat enclosed, how to tighten
We have another Kohler that has a different, but similar design.If you don't want to go the replacement part way, you MAY be able to get by with a toggle bolt solution - it depends how far below the ceramic surface the plastic expander extends.This solution would involve lifting the cover flap over the hinge holes and drilling a hole (1/2 " or so) through center of the plastic screw. Then use a toggle bolt (with a stainless steel washer on one end) and insert the toggle bolt through so it expands on the bottom side of the ceramic surface. Tighten the toggle bolt and flip the plastic cover back over it to hide it.If this doesn't work, you could unscrew your toggle bolt (the "wings" will fall to the floor, sorry) and then use a progressively larger drill bit to drill out the plastic screw, just as one drills out a rivet. The danger is in going too large and making contact with the ceramic, which will likely shatter (or at the very least chip) the bowl. Once you are able to drill out the plastic screw, you can use a larger size toggle bolt and make more secure contact with the back side of the ceramic bowl surface with you toggle wings.
11/5/2013 12:54:04 AM • Kohler 3386-6... • Answered on Nov 05, 2013
One of the screws that secures the toilet seat
Consider using a toggle bolt (with wings) and a large stainless steel washer to re-attach the seat.
11/4/2013 11:46:59 PM • Kohler 3386-6... • Answered on Nov 04, 2013
I have a koehler rialto
Wrap a putty knife with a wash cloth, and push it between the toilet ceramic surface and the plastic hinge for the seat. Wedge it in there. Now try unscrewing the hinge screw. This provides back pressure against the hidden nut on the other side and may let you successfully remove the screw.
11/4/2013 11:45:58 PM • Kohler 3386-6... • Answered on Nov 04, 2013
After flushing, wather doesnt come up in bowl evan if ball close hole good.
These are designed with a very, very low water level - just covering the well at the bottom of the tank. It's part of the design. Our family has made a practice of flushing once beforehand to wet the surfaces before doing any major business on the toilet.
11/4/2013 11:44:08 PM • Kohler 3386-6... • Answered on Nov 04, 2013
Self closing all in one tolet seat boxed, hidden
If you are trying to install a standard toilet seat on a special "smooth sides" toilet, it likely will not work. Most hidden bolt toilets come with a special seat because you cannot get to anything from below. This special seat has a set of expanding style bolts that are attached to the screw that is part of the seat. The plastic expanding bolt goes into the hole(s) on the toilet, and as you tighten the screw on the toilet seat bolts, they expand the plastic part in the hole of the ceramic toilet.
11/4/2013 8:25:55 PM • Kohler 3386-6... • Answered on Nov 04, 2013
Not sure the model, but when I flush the handle
Water pressure in the house may be to high and not allowing flappers to drop. check pressure and adjust as needed.
10/10/2013 2:18:10 PM • Kohler 3386-6... • Answered on Oct 10, 2013
Can not remove toilet seat from Kohler Rialto
to access the nut remove the tank lid, then go down and forward, its there.
8/29/2013 3:31:22 PM • Kohler 3386-6... • Answered on Aug 29, 2013
Flush is weakening. Toilet paper won"t flush
Sorry to read about your problem, I hope this helps you out.
i dont think you have toilet issue,
Try this. take a large bucket, like a paint or home depot orange bucket. fill 1/2 way...
put some toilet paper in the toilet. Then pour the water in fast, and see how it flushes. it it does a easy flush then your drain is ok. if its slow, you have a drain issue and not the toilet.
if that the case, then goto the toilet, and clean out all of the little holes, that are around the unit.. where you see the water come out. they can be clogged up. a small type wire like a clothes hanger.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
5/5/2013 5:54:15 PM • Kohler 3386-6... • Answered on May 05, 2013
My kohler 2007 toilet lever came loose; want to know how the parts fit.
The bolt that holds it on is a reverse threaded bolt. Retighten it going the opposite direction. This should do it.
1/30/2013 3:08:26 AM • Kohler 3386-6... • Answered on Jan 30, 2013
0answers
After installing a new flush
Yes,there it is!You can adjust your water level at the flush valve..You can see the ball there you need to adjust that so that the water level of your tank goes to your desired level.
7/29/2011 10:20:36 AM • Kohler 3386-6... • Answered on Jul 29, 2011
The Rialto toilet makes it
You should be able to remove the tank lid, reach into the cistern and find submerged at the bottom towards the front of the toilet the plastic wing nuts, hold onto these while tightening the plastic bolt from the top.
I have a Kohler toilet with a similar design, not sure if it is this exact model but they look very similar so I hope this works for you.
5/9/2011 6:51:08 PM • Kohler 3386-6... • Answered on May 09, 2011
Does not have flush volume.
Check and make sure the valve on the wall under the tank is fully open, and that the float is not getting hung up on the inside of the tank
3/5/2011 3:36:25 AM • Kohler 3386-6... • Answered on Mar 05, 2011
I can't get to the
I just had the same problem.I can not believe that kohler would design such a flaw. I have four of these toilets in my house,and it would be ridiculously expensive to replace, especially for a seat. To fix it I went to OSH and got some 1/4-20 T nuts, went home cut the bolts off the seat (multi master dremel) with metal cutting blade. With a screw driver tapped the bolt and the small area around the bolt down into the toilet area. Now you have just a porcelain hole. Clean area with solvent (lacquer thinner),get some gel type super glue from hobby shop and put it on inside and top edge of the hole on the toilet. Put some glue around the shaft and under side of the T nut and slip it into the hole.Then put a SMALL bead of glue around where the T nut makes contact with toilet and let it dry aprox 1/2 hour. Now you have a permanent fix.To prevent a problem getting the bolt out in the future,put some anti seize (auto part store) on the threads of the new bolts. Hope this helps.
Good luck
Max
2/20/2011 8:31:15 AM • Kohler 3386-6... • Answered on Feb 20, 2011
Kohler 3386-6 Rialto Skylight Round Front Toilet Logo
66 questions posted
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
View Most Popular
Kohler Home
  • Kohler Home
Most Popular Question
self closing all in one tolet seat
  • Home
