20 Most Recent Jacuzzi Bath Era BK37 959 White toilet bowl and tank Questions & Answers
Probably installed incorrectly. The waste line seal has failed.
Jacuzzi Bath Era... | Answered on Dec 28, 2017
If it resembles a Fluidmaster unit, twist it clockwise to decrease the float height. You may have to flush and recheck the setting to get it just right.
Jacuzzi Bath Era... | Answered on Jul 20, 2017
the fill valve shut off level setting is too high. water in the tank is overflowing in the overflow tube. adjust fill valve to shut off at lower tank level
Jacuzzi Bath Era... | Answered on May 15, 2017
Hi and welcome to Fixya .com my name is john, Fluidmasters are sold at any harware store and have a new flapper , I sould start with that.
Jacuzzi Bath Era... | Answered on Jan 30, 2014
Go to Lowes and get a power plunger (it shoots a blast of water directly at the clog) or get a plumbers snake and work the clog out. Follow up with a liquid Plumber or Draino unless you have a septic tank. Good luck.
Jacuzzi Bath Era... | Answered on Oct 29, 2013
The nut has left hand threads. Turn it the other direction to tighten it.
Jacuzzi Bath Era... | Answered on Jun 04, 2012
Hi, W/D here.
Check the water level in the tank. The force to flush waste comes from there. Normally the fill line is cast into the back of the tank, but sometimes it is on the overflow tube. Raise the level if it is low.
Also, make sure that the tubing from the fill valve is connected to the over flow tube (the tall tube).
Best regards, --W/D--
Jacuzzi Bath Era... | Answered on May 07, 2012
local wholesale plumbing supply house. most are listed in the phone book.
Jacuzzi Bath Era... | Answered on Feb 06, 2012
The white tube goes in the middle of the overflow pipe and usually has a clip to hold in inside the overflow pipe
Jacuzzi Bath Era... | Answered on Aug 28, 2011
You can check with http://www.plumbingsupply.com/tanklidsinventory.html#jacuzzi I think you will find what you need here
Jacuzzi Bath Era... | Answered on Jun 15, 2011
Jacuzzi Bath Era BK37 959 White toilet bowl and tank Logo
72 questions posted
Top Jacuzzi Home Experts
Mike
john h
Bill Johnson
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
View Most Popular
Jacuzzi Home
  • Jacuzzi Home
Most Popular Question
very slow refill tank adjust
  • Home
