20 Most Recent American Standard 2004.014 - Champion Elongated One-Piece Toilet Questions & Answers
American Standard Carlyle Series toilet is
Start with the flapper. They tend to dry up especially with water that contains chlorine. Purchase the American Standard flapper if available for that toilet. Works better than generics.
11/11/2013 11:51:12 AM • American... • Answered on Nov 11, 2013
I just need the tank for a Champion 4 elongated
If it's not a one peace tolet you should find what your looking for here.
http://www.thefind.com/hardware/browse-american-standard-champion-tank
1/30/2011 5:42:00 AM • American... • Answered on Jan 30, 2011
Problem: water tank running water and refilling itself
probably the flapper valve is not seating correctly over the outlet. you can fix it by reaching in and twisting the valve one way or the other till it seats properly and the leak will stop.
5/9/2010 1:41:56 AM • American... • Answered on May 09, 2010
Water seem to be leaking trough the seal
The problem is yout toilet flapper. It will look something like this.
You can find a new one at most hardware stores or at a stoe similar to a Lowe's or Home Depot. Changing them is very easy, usually they are held by two ears on either side of the standpipe. Just remove the old one, hook on the new one and adjust the chain to the lever so that it flushes properly.
These are made of soft plastic or rubber and are affected by stuff in the water. Chlorine especially is hard on them and makes them hard and brittle, causing them not to seal right.
Sometimes dirt will accumulate on the bottom and wiping the bottom off will fix the problem, but it is usually a temporary fix.
Heatman101
1/11/2010 2:34:49 PM • American... • Answered on Jan 11, 2010
What is square box (float) attached to flush valve inside tank
The foam block does a few things: It helps with noise level, helps prevent condensation and also takes up space in the tank to lessen water usage with each flush.
Keep an eye on the outside of the tank and if you don't ever notice any moisture on the outside of the tank then I wouldn't worry about it all!!
4/13/2009 5:34:06 AM • American... • Answered on Apr 13, 2009
I have an American Standard 4035 dual flush toilet. How do I increase the water level in the bowl ?
Adjust the float on the fill valve
8/23/2021 10:14:08 PM • American... • Answered on Aug 23, 2021
Our American standard duel toilet takes to long to refill the tank and sometimes there is not enough water to flush just water down
Depends how old your toilet is, it may be a calcium build up problem on your little inlet pipe inside your tank, but first check your water shut off valve on left side of your toilet near the wall....It may not be open all the way OR the valve has an issue...
7/12/2019 11:28:54 PM • American... • Answered on Jul 12, 2019
My American standard champion 4 sings after I flush it, while it I still filling. Then stops when filled.
Hey, One thing is that maybe there might be some loose plastic shavings in the fill line. From the Factory? or maybe was inside the water line going to the toilet when you connected the line to toilet. Shut off the water and get some towels and something to catch the water and disconnect it from the toilet and use bowl or what ever to catch the water and slowly turn it on and see if anything comes out. Maybe if it is in the line inside the toilet it might fall out by lightly tapping on the fill line inside the toilet to help it fall out. Just a thought when you said it "Sings" that sounds like trash inside the line going to the filler tube and bowl, hey try it who knows it might work. Okay
7/12/2019 12:28:16 PM • American... • Answered on Jul 12, 2019
We have a wall mounted American Standard toilet from the 1970's. The tank has a crack in it. Is it possible to just change out the tank?
Hi, First, carefully remove your tank lid, and place it where it won't break or fall. Look for a four-digit number located on the back of the tank, near the water level mark. This is your tank model number. If the number starts with a two, it is a one-piece toilet. Then....visit this link: https://www.americanstandard-us.com/parts-support/faqs/toilets Good Luck!
5/6/2019 8:23:04 PM • American... • Answered on May 06, 2019
American standard hands free toilet battery pack doesn't work
More likely the sensor has malfunctioned.
11/24/2018 6:54:16 PM • American... • Answered on Nov 24, 2018
American Standard 4061 toilet. Can periodically hear the toilet refilling when not in use. No visible issues. Replaced the flapper. Leak remains. No visible cracks on drain tube or tank.
these are called phantom flushes. the water is slowly leaking around flapper or the is a scratch of the flapper seat. I use fluidmaster parts
11/12/2018 2:22:42 AM • American... • Answered on Nov 12, 2018
How do fix my American standard cadet 3 toilet?
Toilets wear out from mineral deposits. Fixn may cost more then new. Googl used commodes first
11/4/2018 9:08:15 PM • American... • Answered on Nov 04, 2018
American Standard toilet tank won't refill.
Water turned off or fill valve bad.
8/29/2018 9:15:28 PM • American... • Answered on Aug 29, 2018
American Standard 2004.014 - Champion Elongated One-Piece Toilet Logo
6 questions posted
Top American Standard Home Experts
Mike
john h
Ekse
Are you an American Standard Home Expert? Answer questions, earn points and help others
View Most Popular
  • American Standard Home
Most Popular Question
water seem leaking trough seal
  • Home
