20 Most Recent
American Standard 2071.016 Heritage One Piece Toilet Questions & Answers
When flushing toilet, water spins in bowl but does
It's either plugged or the tank isn't filling properly.
If it's the tank then the fill valve in the tank needs to be adjusted. There should be a screw to adjust the float ball. Back the screw out until the fill valve starts to run;let the water run until the tank fills to the fill line then turn the screw back in.Try flushing the toilet. If that doesn't work then the toilet is probably plugged.
If it's plugged you may need to rent/borrow a snake to clear the line.
7/8/2015 10:58:02 AM •
American...
Answered
on Jul 08, 2015
Alot of times this problem occurs when there is not enough water in the tank behind the seat and bowl. Lift off the tank lid and see how much water is it, It should be near full.If it is not your problem is not enough water.
2/22/2010 2:30:18 AM •
American...
Answered
on Feb 22, 2010
Air switch randomly comes on by itself and I have to leave the breaker off
This could be caused by a faulty relay or switch in the control panel. It is best to have a qualified technician inspect the control panel and replace any faulty components. If the issue persists after replacing the faulty components, then it could be a wiring issue and a qualified electrician should be consulted.
2/22/2023 9:40:24 PM •
American...
Answered
on Feb 22, 2023
My American standard champion 4 sings after I flush it, while it I still filling. Then stops when filled.
Hey, One thing is that maybe there might be some loose plastic shavings in the fill line. From the Factory? or maybe was inside the water line going to the toilet when you connected the line to toilet. Shut off the water and get some towels and something to catch the water and disconnect it from the toilet and use bowl or what ever to catch the water and slowly turn it on and see if anything comes out. Maybe if it is in the line inside the toilet it might fall out by lightly tapping on the fill line inside the toilet to help it fall out. Just a thought when you said it "Sings" that sounds like trash inside the line going to the filler tube and bowl, hey try it who knows it might work. Okay
7/12/2019 12:28:16 PM •
American...
Answered
on Jul 12, 2019
