20 Most Recent KitchenAid KFP740 Food Processor Questions & Answers
3answers
How will i pass the job interview?
Dress formal and be confident. Firm hand shake and make eye contact
4/8/2019 1:22:08 PM • KitchenAid... • Answered on Apr 08, 2019
Food processor not working
check cover safety tab possible broken or faulty switch
8/29/2017 1:30:55 PM • KitchenAid... • Answered on Aug 29, 2017
KitchenAid KFP740 9 Cups Food Processor: I used
Most likely it will be to do with the bowl or the lid. The safety mechanisms in both parts are likely culprits, they operate a micro switch just above the switch panel and hidden by the base of the bowl. Have just the bare motor plugged in and turned on with the run button depressed. Now with something plastic depress that small black button, the motor will likely start running. That proves motor is fine and you need to figure out which of the bowl or lid is the faulty part. The pusher needs to be in the lid tube before the motor will run in case you have forgotten.
5/2/2017 8:02:40 PM • KitchenAid... • Answered on May 02, 2017
2answers
Closing the lid completely the processor does not work
See previous answer
9/1/2014 5:04:25 AM • KitchenAid... • Answered on Sep 01, 2014
Spindle / shaft or mixer bowl?
if you say the motor is running but no blades moves in the cup.it means the shaft which is connected to the blades and the motors break down. so i refer u to open it and check which shaft part is broken,or take it to the mechanic.
1/5/2014 3:54:49 PM • KitchenAid... • Answered on Jan 05, 2014
0answers
0answers
I need a copy of
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual or the model number of your food processor is different from the one in the manual.
Thanks for using FixYa.
12/6/2010 2:48:51 PM • KitchenAid... • Answered on Dec 06, 2010
Need owners manual for kitchenaid food processor model # KFP740CR
http://www.kitchenaid.com/flash.cmd?/#/page/home
this site should help you out.
one thing, you can chop onions without crying.
11/8/2009 4:06:32 AM • KitchenAid... • Answered on Nov 08, 2009
Kitchen aid model kfp 7
This may be caused by a number of factors. Most commonly, it is because the work bowl is being over-filled or too much pressure is being exerted on ingredients as they fall through the feed tube. Doing this may cause the disc to come off balance and start sheering plastic.
Call Kitchenaid Customer Service and provide them with this description. They will replace the unit free of charge, regardless of it's age or warranty. Their toll-free telephone number is:
1.800.541.6390.
9/9/2009 7:06:22 PM • KitchenAid... • Answered on Sep 09, 2009
Unit assembled, lights are on (pulse, on) nothing happens
The Kitchenaid food processors have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. I am thinking this is an issue of assembly because the light is on, so the unit is definitely getting power.
Proper assembly is below:
If it isn't all ready, please disassemble the entire unit. This means removing the blade and/or disc, blade, removing work bowl, work bowl lid, and blade.
Start by placing the work bowl onto the motor base. The work bowl handle should be facing at 9 o'clock, which is out to your left. Rotate the handle downward until it locks in at the 6 o'clock position, which will lock over the center of the button panel.
Repeat the process with the work bowl lid. The blade does not need to be present for the motor to engage, if this is an assembly issue.
8/8/2009 12:32:05 PM • KitchenAid... • Answered on Aug 08, 2009
Light is on but blade will not turn
You have a bad sensor switch, when you put the bowl. Locate the sensor switch and replace it.
7/23/2009 10:46:38 PM • KitchenAid... • Answered on Jul 23, 2009
I have the unit plugged in and the ingredients in
I am assuming that the unit is not getting any power whatsoever and this is not isolated solely to the pulse function not working.
The Kitchenaid food processors have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. Proper assembly is below:
7/7/2009 10:38:00 PM • KitchenAid... • Answered on Jul 07, 2009
KitchenAid KFP740 Food Processor Logo
Popular Tags
30 questions posted
Top KitchenAid Food Processors Experts
NOEL
NOEL
john h
Are you a KitchenAid Food Processor Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Food Processors
Most Popular Question
unit assembled lights pulse nothing
  • Food Processors
