20 Most Recent KitchenAid KFP750 Food Processor Questions & Answers
Hey I had the same problem. This may sound primitive and stupid but it worked. Give the stem a good whack with a wooden spoon all the way around, it will come off.
KitchenAid... | Answered on May 27, 2019
The plastic for the work bowl / handle is molded and one piece and cannot be disassembled. My best recommendation is to call Kitchenaid customer service to see what recommendations they have. Within one year warranty, they may replace the work bowl at no cost.
Their toll-free number is: 1-800-541-6390.
KitchenAid... | Answered on Apr 20, 2019
Have you tried heating the sleeve with a torch and then sliding it on?
KitchenAid... | Answered on Nov 09, 2017
Hi, I had the same problem with my KitchenAid KFP740. The fix was the handle cap was loose. We all have a tendency to lift the unit out of the cabinet by the handle and it is heavy! The handle has a mechanism inside. The outside piece of the handle that holds it all inside gets loose making the pin at the bottom of the bowl not reach where it needs to be when you put the lid on. If you assemble the unit and squeeze the top of the handle after you put the lid on mine would work. A little gorilla glue and I was back in business!
KitchenAid... | Answered on Nov 02, 2017
repairing these items are not cost effective
you can take it to an appliance repair shop but parts if available will be close to the cost of a new unit
KitchenAid... | Answered on Aug 24, 2016
Soak overnight in a bucket of hot water, dish soap and 2 cups of bleach. By the morning the dirt will be gone and just need rinsing..
KitchenAid... | Answered on Jan 09, 2016
Take everything off and see if you can activate the motor with the safety switch. It is located at the front above the button panel normally covered by the working bowl. Mixer plugged in and turned on press that button switch in with something non metallic. If the motor goes then fault will be with the mechanisms that activate that switch in either the bowl or the lid. The lids are slightly more likely to be the problem than the bowl. Only a new part will properly solve it.
KitchenAid... | Answered on Sep 01, 2014
You may have to direct those enquiries at a Kitchen Aid service agent in your country. Here in Australia/New Zealand the bowl parts care not screwed together so it may be a bowl specific to your country.
KitchenAid... | Answered on Mar 25, 2014
It will be the blade holding the bowl on. The blade has become locked onto the motor shaft, in the end you are going to need to replace both. Take it to a K/A service agent.
KitchenAid... | Answered on Dec 21, 2013
The motor shaft sleeve and spindle will need to be replaced, once this jamming has happened it becomes ongoing if you do not replace those inexpensive parts. You need to wrap some webbing tightly around the spindle attach the other end to something very solid (like a fence post) and then accelerate the motor part rapidly away from the post. Hold onto the motor very firmly or it will land on the ground.The webbing tightens instantly when it runs out of slack and the spindle will come off. Then you need to remove the motor shaft sleeve in a similar manner, I drill a hole in the end and use a shackle and chain attached to the post for that one. I use the leg of my workshop bench, most folks will not have a solid heavy bench like mine. If that sounds too hard just take it to your local K/A service agent, they will have done it many times.
Replace the motor shaft sleeve AND multi purpose blade.
KitchenAid KFP750 Food Processor Logo
62 questions posted
Top KitchenAid Food Processors Experts
ThaMp3Doctor
ThaMp3Doctor
Zhareese
john h
Are you a KitchenAid Food Processor Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Food Processors
Most Popular Question
handle food particals under
  • Food Processors
