20 Most Recent American Standard Toilet Tank 4021.016.020 Questions & Answers
You may need to adjust the thing on the inside of the tank that balances the stopper. My father had to do it once, and it was a wuick fix.
American... • Answered on Oct 24, 2010
Your ball **** needs replacement (water control valve), Also your flapper or tilt valve disk is leaking water through it and it needs replacement also.
American... • Answered on Sep 13, 2009
Depends how old your toilet is, it may be a calcium build up problem on your little inlet pipe inside your tank, but first check your water shut off valve on left side of your toilet near the wall....It may not be open all the way OR the valve has an issue...
American... • Answered on Jul 12, 2019
Hey, One thing is that maybe there might be some loose plastic shavings in the fill line. From the Factory? or maybe was inside the water line going to the toilet when you connected the line to toilet. Shut off the water and get some towels and something to catch the water and disconnect it from the toilet and use bowl or what ever to catch the water and slowly turn it on and see if anything comes out. Maybe if it is in the line inside the toilet it might fall out by lightly tapping on the fill line inside the toilet to help it fall out. Just a thought when you said it "Sings" that sounds like trash inside the line going to the filler tube and bowl, hey try it who knows it might work. Okay
Hi, First, carefully remove your tank lid, and place it where it won't break or fall. Look for a four-digit number located on the back of the tank, near the water level mark. This is your tank model number. If the number starts with a two, it is a one-piece toilet. Then....visit this link: https://www.americanstandard-us.com/parts-support/faqs/toilets Good Luck!
American... • Answered on May 06, 2019
More likely the sensor has malfunctioned.
American... • Answered on Nov 24, 2018
these are called phantom flushes. the water is slowly leaking around flapper or the is a scratch of the flapper seat. I use fluidmaster parts
American... • Answered on Nov 12, 2018
Toilets wear out from mineral deposits. Fixn may cost more then new. Googl used commodes first
American... • Answered on Nov 04, 2018
Water turned off or fill valve bad.
American... • Answered on Aug 29, 2018
American Standard Toilet Tank  4021.016.020 Logo
3 questions posted
Top American Standard Home Experts
Mike
john h
Tom Chichester
Are you an American Standard Home Expert? Answer questions, earn points and help others
View Most Popular
  • American Standard Home
Most Popular Question
water leaking into bowl from tank
  • Home
