20 Most Recent KitchenAid KFP670 Ultra Power Food Processor Questions & Answers
Here is a link to the User Manual on KitchenAid's website: http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209705148.pdf
Your model number is a kfp670 ob, the last letters stand for onyx black.
If you ever need any replacement parts, remember us here at the Mending shed. We are one of KitchenAid's largest service centers in the US, and everything we carry is genuine KitchenAid replacement parts.
Thank you,
ColleenCustomer ServiceMendingShed.com800-339-9297
KitchenAid... | Answered on Apr 12, 2013
The Kitchenaid website doesn't recognize the model number you gave. Could it possibly be KFP760? If so, then here's a link to the free downloadable manual.
http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/KFPW760OB_Use%20and%20Care.pdf
KitchenAid... | Answered on Jan 28, 2013
I am assuming the unit is getting power. The "power" LED should be lit up on the front of the unit.
The Kitchenaid food processors have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. Proper assembly is below:
If it isn't all ready, please disassemble the entire unit. This means removing the blade and/or disc, blade, removing work bowl, work bowl lid, and blade.
Start by placing the work bowl onto the motor base. The work bowl handle should be facing at 9 o'clock, which is out to your left. Rotate the handle downward until it locks in at the 6 o'clock position, which will lock over the center of the button panel.
Repeat the process with the work bowl lid. The blade does not need to be present for the motor to engage, if this is an assembly issue.
If this has not resolve the issue, please ensure the outlet is receiving power.
If the unit is still not functioning, take a close look at the bottom of the work bowl where it meets to the motor base. The work bowl, when locked in, depressed a gray plastic peg. This is the safety mechanism. You may trying depressing this peg on your own with a pencil. If this activates the motor, this may indicate your work bowl is no longer seating correctly.
Also check the work bowl handle to make sure nothing is cracked. There is a plastic assembly in the handle that acts as a second safety feature.
If either of these things seems to be the culprit, I would suggest seeking a new work bowl or work bowl lid to correct the issue.
KitchenAid... | Answered on Oct 05, 2011
i am also having the same problem. it happened as soon as i got done putting in some parmesan and grated it. never happened before and i've got a few cups of parmesan cheese just sorta wasting away inside the processor. very tempted to break the damn thing open and just buy a new processor from a different company.
KitchenAid... | Answered on Apr 10, 2010
With the food processor I have it will not allow you to remove the bowl unless the top is off.Try take the top off or putting it on.Then remove it from the processor.
KitchenAid... | Answered on Apr 19, 2009
I have the 11 cup Kitchenaid food processor and did the same thing this weekend. It took a while but finally figured out how it went back together. Hopefully the pictures help. I know it's difficult to see since the pieces are all black. Good luck!
KitchenAid Food... | Answered on Jun 01, 2019
Store it with the lid upside down on top of the bowl
KitchenAid Food... | Answered on Apr 21, 2019
Make sure you have the bowl, lid and sometimes the pusher assembled correctly. If everything is not correct it will not activate the safety switch to allow it to start up.
KitchenAid Food... | Answered on Feb 28, 2019
take it back and get a warranty replacement unit
reading the user manual may be a help
KitchenAid Food... | Answered on Sep 10, 2018
Possibly something about either the lid or the bowl has become deformed. Very likely you will need to replace one or the other.
KitchenAid Food... | Answered on Sep 08, 2018
Does the actuator push down far enough to catch the button at the bottom? I repaired one simply by adding a vinyl screw cover to the top of the button so it was tall enough to be reached by the actuator.
KitchenAid Food... | Answered on Jul 18, 2018
The solution is 90% going to be replace the lid, or replace the bowl or if you are very unlucky replace both. A proper KitchenAid service agent should have both parts on the shelf and will be able to try a new one of either to see where the fault lies. I think over the years I've replaced more lids than I have bowls.
KitchenAid Food... | Answered on Feb 28, 2018
KitchenAid KFP670 Ultra Power Food Processor Logo
Popular Tags
19 questions posted
Top KitchenAid Food Processors Experts
ThaMp3Doctor
ThaMp3Doctor
Zhareese
john h
Are you a KitchenAid Food Processor Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Food Processors
Most Popular Question
kitchenaid food processor 770 run
  • Food Processors
