20 Most Recent KitchenAid KP26M1X Stand Mixer Questions & Answers
I had a similar problem with mine - the problem turned out to be that I hadn't clicked the bowl into place corectly. If you find the bowl is tilting forward slightly then you probably need to push it into the clip at the back.
KitchenAid... | Answered on Aug 30, 2019
Model number would be a good idea to start with
KitchenAid... | Answered on Jul 25, 2017
Both answers are adequate the first being slightly superior. Fiddling with the mixer if it is new from the retailer or an authorized re-seller could void the Warranty.
Kitchen-Aid has the best warranty on the planet, truly no questions asked from date of registration or date on purchase receipt it simply is return for replacement no questions asked and it is EXACTLY 365 days long. At day 366 expect to pay for anything that is wrong with the mixer.
Some people wait a long time to get their Kitchen Aid mixer and are not familiar with the machine over all. When you attach the mixing paddle whip hook, you must rotate the instrument around the shaft until it finds the mounting pin slot and that will allow the paddle to be pulled up about 1/2 inch higher and then twisted into the final locked position for operation. I know it sounds silly or simple but as a tech I have had to answer this question a time or two over the last 15 years. Always when the operator sees how it attaches I get the "awwww that's too simple"
Now to the meat of the problem. The motor still ran but with any load, the paddle/dough hook/wire wisk would not turn. This is a gear problem under the transmission cover. I would personally believe that if this is a new machine then the worm gear axel has popped out of its locked position or a gear tooth has broken. In which case you can get it repaired locally for about $80.00 if it is out of warranty. Or by KitchenAid for about $120.00 (you have to send it away if you don't live near a repair center) if it is out of warranty.
If it is still in warranty even if it is day 364, KitchenAid (Whirlpool-they own KA) They will send a new machine and a shipping label for return shipping with no out of pocket costs from you. You unload the replacement machine and repack the container with the bad machine and send it back. If you try to keep the old machine and the new one you will get charged full retail. You see you will need a working credit card to get the service. Or you will need to take it to a service center or mail it back first if you do not have a credit card. The 600 weighs 29 pounds and cost by USPS about $37.00 to ship up to 1200 miles. UPS will charge about $8.00 dollars more unless you have a UPS account then possibly less. FedEx Ground may also be an option.
Packing material to ship back if you have not kept the original OEM packaging is about $12.00 unless you have access to material as a part of your life. I think that is about it. Unless you want repair instructions which are available right here on FixYa. Let us know if this helps you. if not get back to us so that we can help FixYa.
KitchenAid... | Answered on May 04, 2017
hi i have used this link m any times to fix mine and a few friends
also when your ready to order the parts
go to
www.partstore.com
they have better than average prices
KitchenAid... | Answered on Mar 10, 2017
The model number shown is for the Professional series which does not have a separate rear cover. Below are links to KitchenAid mixer Service Manuals:
Professional 5/6 quart
http://ep.yimg.com/ty/cdn/mendingshed/kitchenaid6qtservicemanual.pdf
4.5/5 quart
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
KitchenAid... | Answered on Jan 28, 2015
Go here and put that model number into the search box
http://www.kitchenaid.com/customer-service/manuals/
KitchenAid... | Answered on Dec 25, 2013
That should just lift off, I'm not familiar with your particular model but all the bevel gears I have seen just drop onto a pin that is just a push fit through a hole in the shaft.
KitchenAid... | Answered on Nov 07, 2013
when you replaced the planetary you forgot to put the retaining spring clip back on,
KitchenAid... | Answered on Oct 17, 2013
replace the brushes in the unit.
KitchenAid... | Answered on Dec 04, 2012
Yes, they are the compatible and can be swapped.
KitchenAid... | Answered on Nov 08, 2010
Sounds like a bad worm gear.
smallappliance.com has replacement parts. Take the head apart to confirm.
KitchenAid... | Answered on Oct 27, 2010
SmallAppliance.com
I ordered a new worm gear for mine which should arrive any day now.
Food Mixers Logo
46 questions posted
Top KitchenAid Food Mixers Experts
Appliance engineer
Colin Stickland
Colin Stickland
Lee Hodgson
Lee Hodgson
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Food Mixers
Most Popular Question
purchased new kitchenaid
  • Food Mixers
