20 Most Recent KitchenAid KHHS179LSS Convection / Microwave Oven Questions & Answers
You have a shorted grille relay on your control board. I can repair this for $69.95, which includes insured return shipping.
For details and more free DIY and other help & advice, feel free to contact me.
William E. Miller, AS-EET
[email protected]
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
KitchenAid... | Answered on Mar 16, 2017
Magnetic screwdriver with extended shaft.
If you have chewed the screws get a screw removal bit and use a torque driver.
KitchenAid... | Answered on May 13, 2014
After replacing the internal fuse (see other posts to see how I did it) the microwave is working fine (so far). We have used it 5 or 6 times without any issues.
Check the hi voltage fuse. It's located near the klystron tube.
KitchenAid... | Answered on Jan 05, 2014
see the video attached. and fix it. God bless you
KitchenAid... | Answered on Oct 28, 2013
see the video and fix it. GOD BLESS YOU
SEE THE FIGURE AND PROCEED ACCORDING. GOd bless you
remember try that the screwdriver can be isolate it.
I am having the same problem. According to the owner's repair guide error Code F7 indicates that power to the magnetron was interrupted. You will want to make the following checks: 1. Unplug microwave oven or disconnect power. 2. After 40 seconds, check to see whether this solves the problem. 3. Unplug microwave oven or disconnect power. 4. Check resistance of the magnetron thermostat. 5. Check the magnetron. 6. Check wiring to the 1100W inverter and control system. See "Checking Inverters." 7. Plug in microwave oven or reconnect power. 8. Check operation of all interlock switches. Check door, hinge and cavity front alignment. Adjust as needed. 9. Unplug microwave oven or disconnect power. 10. If switches operate correctly, replace 1100W inverter. 11. If problem persists, replace electronic control. 12. Plug in microwave oven or reconnect power.
While this is helpful, it is still out of my confort zone as I pulled the control panel and discovered a virtual zoo of connectors. Obviously ponly a trained repairman knows which ones need to be checked. I will probably have to resort to calling one and shelling out the dough.
KitchenAid... | Answered on Jul 19, 2013
This sounds like the magnetron has failed, the pop sound is a classic sysmptom.
KitchenAid... | Answered on May 19, 2012
KitchenAid KHHS179LSS Convection / Microwave Oven Logo
67 questions posted
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Microwave Ovens
Most Popular Question
kitchenaid khhs179lss 1100 watts r ni
  • Microwave Ovens
