20 Most Recent Krups Fresh Aroma 625 Coffee Maker Questions & Answers
Cleaning the Machine
- Never wash your espresso machine accessories in the dishwasher.
After use, the water container must be emptied.
• Drip tray
This must be emptied after using the appliance by taking off the grid See figure (19)below. If several espressos are being prepared one after the other, the drip tray should be emptied from time to time (about once every 7 - 8 espressos). The presence of water is normal and does not signify a leak. If necessary, clean the drip tray and its grid with water and a little non-abrasive washing-up liquid, rinse and dry. When reassembling the machine, ensure that the plastic lining is in the right place See figure (20) below.
• The brewing head, the filter basket and the filter holder
These must be cleaned after each use. All you need to do is wipe a damp cloth over the brewing head of your appliance and to wash the other accessories in water and a little non-abrasive dishwashing liquid, rinse and dry. If the brewing head is heavily clogged up, unscrew the grid using a coin, clean it and refit it, pressing down firmly See figure (21)below.
When your espresso machine is not being used, do not leave the filter holder in the appliance to prevent wear on the gasket.
• The cup warming plate: remove this to clean it with water and a little non-abrasive dishwashing liquid, rinse and dry.
• The cappuccino accessory
For more thorough cleaning the cappuccino accessory can be dismantled from the appliance.
Descaling
Descalling (SIC) is necessary to keep your espresso machine running efficiently.
As a result descaling of your espresso machine should be done fairly frequently
with citric or tartaric acid.
• Use caution when descaling your espresso machine as the acid substance within the descaling powder may damage countertops or any other surface it comes in contact with.
However, we would advise you to use the reference solution as W F054 that is available from Krups. Descaling depends on the hardness of the water, but also on the frequency of use.
To descale, follow the following method:
• Unscrew the grid from the brewing head of the appliance and clean it See figure (21)below.
• Dissolve a packet of KRUPS descaling solution in 17 oz1510 ml of lukewarm water and pour the whole batch into the empty water container.
• Place a container under the brewing head. Run through about 1/3 of the liquid immediately, setting the selector to the position See figure (9)below.
• Stop the appliance, leaving the position See figure (9)below engaged and wait for 10 - 15 minutes to allow the descaler to take effect.
• Next, start the machine again and allow the rest of the liquid to run through.
• Then rinse with two water containers of fresh water and replace the grid on the head of the appliance (see section on “Cleaning the machine”).
The warranty does not include espresso machines that do not function, or do not function properly, because descaling has not been carried out.
Krups Fresh... • Answered on Feb 17, 2011
I need user manual for Krups fresh aroma 625 coffee maker
Krups Fresh... • Answered on Aug 25, 2010
i had that happen to me. turns out the filter cover (flat plastic circle with a rectangular hole) wasn't seated correctly.
Krups Fresh... • Answered on Apr 18, 2009
Maybe you need to supply the model as well, it's not an error code on the models I'm familiar with. Try editing it into your question or ask a new question with the information within it.
Krups Coffee... • Answered on Feb 07, 2021
ALL DOLCE GUSTO MACHINE HAVE A TEMPERATURE BETWEEN 60C TO 80 NOT OVER
Krups Coffee... • Answered on Jan 22, 2021
you have to open it. you probably have to replace the seal from under the boiler. quit a bit of doing but if you do it slowly you will be able to make it take photos if you have to
very bad news, if it keeps heating the thermal safety, will eventually blow due to overheating .you may have a shorted switch or PCB mainboard shorted and is keeping the machine on at all time which is more likely to happen even sow when having internal leaking .
Krups Coffee... • Answered on Jan 13, 2021
Try this, remove the tank, the drip tray, the bin on the side and the sliding thing above the bin. Hold down the on and steam buttons while plugging the machine into a live socket, it's either that or the same again but holding down the on button and the program button while plugging it in. You will get a screen that says something like " Remis a something vende" which is French for put it into sale state, you choose "Oui" for yes. It's been a long time since I've done one but that's as best as I can recall. It will zero the coffee counters as well.
Krups Coffee... • Answered on Nov 28, 2020
Krups would be a possible source.
Krups Coffee... • Answered on Nov 17, 2020
Try this, remove the tank, the drip tray, the bin on the side and the sliding thing above the bin. Hold down the on and steam buttons while plugging the machine into a live socket, it's either that or the same again but holding down the on button and the program button while plugging it in. You will get a screen that says something like " Remis a something vende" which is French for put it into sale state, you choose "Oui" for yes. It's been a long time since I've done one but that's as best as I can recall. It will zero the coffee counters as well. https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ALeKk02VetSw_f-MdUcfZ3oveWE2qJRjhQ:1604423278014&q=Krups+EA880810.+How+can+I+hard+reset ..
Krups Coffee... • Answered on Nov 10, 2020
It can cause problems if it doesn't work correctly. To test the thermostat in a drip coffee maker: Step 1: Unplug the unit, empty excess water from the reservoir, turn the unit over, and remove the base. ... Step 3: If defective, remove and replace the thermostat with one of the same rating. https://home.howstuffworks.com/how-to-repair-small-appliances3.htm
Krups Coffee... • Answered on Apr 01, 2020
Krups Fresh Aroma 625 Coffee Maker Logo
Popular Tags
9 questions posted
Top Krups Coffee Makers & Espresso Machines Experts
Ross Keen
eyecam
Jean Sintulaire
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Krups Coffee Makers & Espresso...
  • Krups Coffee Makers & Espresso...
Most Popular Question
krups anticalc kit descaling
  • Coffee Makers & Espresso Machines
