20 Most Recent Krups ProAroma 453-71 Coffee Maker Questions & Answers
The culprit is probably the thermal fuse. It's under the bottom cover, and you have to have Torx security bits (the ones with the holes in the middle) to remove the three screws holding it in place. Sadly, the thermal fuse is not resettable. Once it's tripped, it's dead. If you have this problem, forget about getting Krups or their lame service agent, smallappliance.com, to repair it. Both contacts I had with Krups were unsatisfactory. The factory/customer service folks say that there are no parts available and to buy a new coffee pot. Great solution. You can damn well believe it won't be a Krups. Or is it ****? An otherwise perfectly functioning unit gets sent to the landfill because the folks at Krups can't be troubled to find the part number. Idiots. For your info, there are thermal interrupters made by several manufacturers. The trip temperature on the breaker is 318 degrees, C. Something in the neighborhood of 200 degrees C would probably work, but would have to be soldered in. If you are comfortable with doing that, it's a solution.
Krups ProAroma... • Answered on Jan 07, 2018
may be its not heating properly try some descaleing
Krups ProAroma... • Answered on Mar 09, 2016
Many times the Thermal (not Thermo) fuse is soldered in line with silver solder and unless you have the ability to cut the old one out and replace it, the cost would be greater than a replacement coffee maker.
Krups ProAroma... • Answered on Jan 05, 2015
Contact Krups, and they should be able to send you out a new one. Their phone number (according to their website, www.krupsusa.com ) is 1-800-526-5377
Good luck! :)
Krups ProAroma... • Answered on Nov 05, 2012
Thermal fuse gets stuck, gently take it apart and reverse the thermal button over, clean the rust under the button
Krups ProAroma... • Answered on Jan 25, 2011
unplug the coffee maker. Let the unit cool down for say a half hour. Try another pot of coffee and see if it comes on after plugging it back in of course
Krups ProAroma... • Answered on Oct 31, 2010
I put a mixture of water and vinegar thru the coffee maker and let it sit for about one hour. Then i rinse clear water thru and its find.
Thanks.
Krups ProAroma... • Answered on Jun 06, 2009
The wavy lines indicate the carafe pre-heat function. When it is ON the red light blinks for several minutes and the goes on solid. It doesn't start brewing until the light is solid red.
Mine also doesn't seem to keep hot also.
Krups ProAroma... • Answered on Apr 07, 2009
Sounds like the thermal fuse (search this database under "fuse" and you'll find a discussion of it). I have yet to find the proper TORX security wrench, so I haven't been able to get to mine in order to try the things mentioned there, but I have a similar problem and what is said there makes sense.
Krups ProAroma... • Answered on Mar 31, 2009
Just found the answer!
The type 453 coffee maker offers a carafe ‘pre-warm’ function.
This feature will heat the carafe for 5-10 minutes before the brewing process begins and is indicated by a flashing red light.
To toggle this feature, push the top-right button in the control panel until the display reads "off".
Krups ProAroma... • Answered on Aug 16, 2008
then try Krups directly we do not know if they sell parts or not
Krups Coffee... • Answered on Jun 12, 2021
Krups ProAroma 453-71 Coffee Maker Logo
33 questions posted
Top Krups Coffee Makers & Espresso Machines Experts
Ross Keen
eyecam
Jean Sintulaire
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Krups Coffee Makers & Espresso...
  • Krups Coffee Makers & Espresso...
Most Popular Question
coffe not stay hot in carafe
  • Coffee Makers & Espresso Machines
