20 Most Recent Krups Novo 3000 /FNC3 Espresso Machine Questions & Answers
If you have not been cleaning the inside water lines, lime deposits form and clog the lines. When a coffee make sits for a period of time, deposits form inside the lines and act as crystals to block or obstruct the inside of the line. Pass a small wire into the line and brake the deposits loose. Flush the lines accordingly.
Krups Novo 3000... | Answered on Feb 03, 2018
If it's only 18 months old surely it will still be under some sort of manufacturers guarantee, you don't bin 18 month old coffeemakers nor should you be paying to fix them. Put the problem back in their lap.
Krups Novo 3000... | Answered on Aug 05, 2017
Solution: Replace steel cup strainer. Follow-up question -- who knows of source for this item in Guadalajara, Mexico????
Krups Novo 3000... | Answered on Sep 18, 2009
Dig out as much of the coffee as you can then rinse under ho water faucet in kitchen sink until coffee is dissolved or flushed. You could also try soaking portafilter in a solution of purocaff or cleancaff be careful though you do not want the plastic parts in the solution for too long.
Krups Novo 3000... | Answered on May 14, 2009
This is a ******** side no help from the "experts".Look at the Date!
Krups Novo 3000... | Answered on Feb 12, 2009
means the temp is not high enough or pressure not high enough
1) descale the machine real good
2) if not workin your thermostat or brewer can be broken.
Let me know if you still have problems after this descaling
And by the way poke a needle through the steam spout as that can be clogged too..
have fun
Krups Novo 3000... | Answered on May 05, 2008
The advice is to disconnect it for an hour to reset it.. Lots of issues with that machine
https://www.bean2cup.org/forums/index.php?showtopic=18644
Krups Coffee... | Answered on Aug 20, 2020
It can cause problems if it doesn't work correctly. To test the thermostat in a drip coffee maker: Step 1: Unplug the unit, empty excess water from the reservoir, turn the unit over, and remove the base. ... Step 3: If defective, remove and replace the thermostat with one of the same rating.
https://home.howstuffworks.com/how-to-repair-small-appliances3.htm
Krups Coffee... | Answered on Apr 01, 2020
Error code 5 is a result of one of the following:
Blocked water circuit (water meter, pump, distributor, distributor motor, microswitch)
Krups Coffee... | Answered on Mar 10, 2020
Hi! Did You fixed the problem? I got same error and have no idea whats the point :(
Krups Coffee... | Answered on Feb 17, 2020
That model had a likelihood of the electrovalve growing a green crystal inside the fitting where the teflon tube comes from the boiler. The electrovalve is a solenoid operated tap on the steam wand side accessed by removing the lid and the side cover. I used to take the electrovalve off completely to do the job. To get the teflon tube out you depress the silver collar around the tube towards the fitting and pull on the tube. It won't come out unless you depress the collar. You then unscrew that same fitting and clear the green crystal out with a probe or screwdriver and rinse or blow the fitting out. The fitting was sealed from new into the electrovalve with some sort of sealant product, I used to clean out the threads and use some thread tape, I never had a leak and did heaps of them over the years.
Krups Coffee... | Answered on Nov 07, 2019
Found on the internet:
Try this, remove the tank, the drip tray, the bin on the side and the sliding thing above the bin. Hold down the on and steam buttons while plugging the machine into a live socket, it's either that or the same again but holding down the on button and the program button while plugging it in. You will get a screen that says something like " Remis a something vende" which is French for put it into sale state, you choose "Oui" for yes Hope this helps
Krups Coffee... | Answered on Oct 30, 2019
I found this on the internet:
Krups Novo 3000 /FNC3 Espresso Machine Logo
Popular Tags
12 questions posted
Top Krups Coffee Makers & Espresso Machines Experts
Charles Tidwell
Marvin
Marvin
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Krups Coffee Makers & Espresso...
  • Krups Coffee Makers & Espresso...
Most Popular Question
bottom broken steel cup w strainer
  • Coffee Makers & Espresso Machines
