20 Most Recent Krups Orchestro Dialog FNF2 Espresso Machine Questions & Answers
When you do what the machine asks you to do what happens?
Krups Orchestro... | Answered on Sep 27, 2017
Go to krupsusa.com and click on "instructions" they should have the manual to download.
Krups Orchestro... | Answered on May 08, 2017
You may find the transformer supplying power to the pcb has gone open, there is a fuse in it that can fail. I have bypassed the dead fuse on many of them in the past. If you don't understand what I have told you then best you do not try doing it, you need to understand where to solder the link. A proper service person familiar with the model should be able to figure it out once you have informed them what the problem is.
Krups Orchestro... | Answered on Feb 10, 2016
On mine, the coffee dispenser had become stuck or clogged with ground coffee. cleaning this and giving it a bit of assistance on the next power up solved the problem. you will need to remove the two TX-15 torx screws at the front under the coffee flap/lid and the water flap/lid. there are also four screws down the back which dont have any screw driver slots in them. you will need a pair of vice grips or similar pliers to undo them. The top then lifts off and you can see down the coffee dispenser enough to clean it out. If you intend to test it with the lid off you will need to tape a magnet on the gray reed switch at the top (to simulate the ground coffee lid being closed). Obviously if you remove the two last screws at the bottom back you can easily remove the sides however in my case this wasn't necessary.
Krups Orchestro... | Answered on Jan 30, 2016
Contact the authorized service center.
Krups Orchestro... | Answered on Jan 07, 2016
It cannot be an FNF2 and also an XP7220, they are entirely different machines.
Krups Orchestro... | Answered on Oct 19, 2013
Can you elaborate on where the leak is? Is it plain clean water or coffee? [email protected]
nned more info. Dazza REPAIRER
Krups Orchestro... | Answered on Sep 24, 2011
Krups Orchestro Dialog FNF2 Espresso Machine Logo
54 questions posted
Top Krups Coffee Makers & Espresso Machines Experts
Charles Tidwell
Marvin
Marvin
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Krups Coffee Makers & Espresso...
  • Krups Coffee Makers & Espresso...
Most Popular Question
krups fnf2 service 8 mean
  • Coffee Makers & Espresso Machines
