20 Most Recent Krups Crystal Arome Plus Time 467 Coffee Maker Questions & Answers
The manual is available here. Amazon.com, of all places. Whod'a thunk it?
Krups Crystal... | Answered on Feb 09, 2019
The auto off is configurable as I recall. I don't think you can fully hobble. Coffee kept hot much longer goes bad despite the prolonging powers of the Krups. RTFM online and you should be able to learn the menu command sequence to configure it as you like subject to whatever it allows.
Krups Crystal... | Answered on Jun 13, 2009
OH Yeah!
That is the number one failure in these machines. (owned four of them)
The problem is one or both of the "twin" thermal fuses or the thermostat for water
heating and hotplate,( one in the same) has gone open. I have tried for a long time to locate correct replacement parts to no avail. I would STRONGLY not recommend trying to bypass as these are not only controls but a safety feature as well. I was lucky a wile back and found one without a carafe at a garage sale. used it for parts, now those have failed also. Really miss them. If I ever find a source for parts I will post it here with replacement procedure.
EfACTOR
I had same problem. Could not find manual on-line so I tried different techniques. You can reset the auto-off feature to extend the "On" time up to 3 hours max. You do it by (1) placing the control switch in the "Off" position. (2) Simultaneously push the "Hr" and "Min" buttons. The time display will start flashing the hold time. (3) Push the "Hr" button to cycle through the available hold times, 1 - 2  or 3 hours. When set, turn the selector switch momentarily to any other position to finish the programing.
Krups Crystal... | Answered on May 16, 2009
It means your water filter needs to be replaced. I wouldn't know this either as I found my coffee maker in a thrift shop, but I read it on Epinions a few minutes ago in a review.
Have you had any problems with splashing when brewing - some of the water missing the spout? I lose up to a cup of water and I'm stumped. The goldtone filter has to be pushed to go down into the unit, does this mean I'm putting it too far in and screwing up the stop n pour or something?
Krups Crystal... | Answered on Jan 15, 2009
It can cause problems if it doesn't work correctly. To test the thermostat in a drip coffee maker: Step 1: Unplug the unit, empty excess water from the reservoir, turn the unit over, and remove the base. ... Step 3: If defective, remove and replace the thermostat with one of the same rating.
https://home.howstuffworks.com/how-to-repair-small-appliances3.htm
Krups Coffee... | Answered on Apr 01, 2020
Error code 5 is a result of one of the following:
Blocked water circuit (water meter, pump, distributor, distributor motor, microswitch)
Krups Coffee... | Answered on Mar 10, 2020
Hi! Did You fixed the problem? I got same error and have no idea whats the point :(
Krups Coffee... | Answered on Feb 17, 2020
That model had a likelihood of the electrovalve growing a green crystal inside the fitting where the teflon tube comes from the boiler. The electrovalve is a solenoid operated tap on the steam wand side accessed by removing the lid and the side cover. I used to take the electrovalve off completely to do the job. To get the teflon tube out you depress the silver collar around the tube towards the fitting and pull on the tube. It won't come out unless you depress the collar. You then unscrew that same fitting and clear the green crystal out with a probe or screwdriver and rinse or blow the fitting out. The fitting was sealed from new into the electrovalve with some sort of sealant product, I used to clean out the threads and use some thread tape, I never had a leak and did heaps of them over the years.
Krups Coffee... | Answered on Nov 07, 2019
Found on the internet:
Try this, remove the tank, the drip tray, the bin on the side and the sliding thing above the bin. Hold down the on and steam buttons while plugging the machine into a live socket, it's either that or the same again but holding down the on button and the program button while plugging it in. You will get a screen that says something like " Remis a something vende" which is French for put it into sale state, you choose "Oui" for yes Hope this helps
Krups Coffee... | Answered on Oct 30, 2019
I found this on the internet:
Krups Crystal Arome Plus Time 467 Coffee Maker Logo
11 questions posted
Top Krups Coffee Makers & Espresso Machines Experts
Charles Tidwell
Marvin
Marvin
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Krups Coffee Makers & Espresso...
  • Krups Coffee Makers & Espresso...
Most Popular Question
krups coffee pot stopped brewing after
  • Coffee Makers & Espresso Machines
