20 Most Recent Solar Fan Impressions 3 Speed/4 Wire Ceiling Fan Switch Questions & Answers
Replacing 3 speed 4 wire
Copy following link for 3-speed fan wiring:http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#3-speed If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
6/30/2012 10:33:16 AM • Solar Fan... • Answered on Jun 30, 2012
2answers
I have a 3 speed
Did you get a wiring diagram with the switch/fan? This should tell you which is which.
Each manufacturer has different color coding. If you didn't get a diagram, contact the manufacturer for instructions.
Good luck,
Handie Andie
3/25/2011 10:19:44 PM • Solar Fan... • Answered on Mar 25, 2011
Energy Buster
12/13/2023 3:13:19 PM • Solar Electrical... • Answered on Dec 13, 2023
Recommendation for solar generator for Kenmore refrigerator
Just plug it into the wall socket in the condo and stop making complicated solutions to fix something so simple. I hope your balcony is big enough, and remember the solar panels only charge the power source so you also need batteries and an inverter. https://www.google.ca/search?q=blu+solar+energy& ..
7/13/2023 4:03:11 AM • Solar Electrical... • Answered on Jul 13, 2023
I purchased a planter box with a solar light pole. After opening the box, there are no screws, etc. to put it together. What can you do for me?
Not much! Go and buy some screws or take it back from where you bought it from for a refund.
12/13/2020 6:17:08 PM • Solar Electrical... • Answered on Dec 13, 2020
Need instructions for Wild Game Innovations 12 volt solar panel model #SP-12V1
Diesel generator set website: www.dieselgeneratortech.com
12/3/2019 1:47:16 AM • Solar Electrical... • Answered on Dec 03, 2019
Solar electricity set up
Why not choose diesel generator set, it is good. It can be used as standby or emergency unit to supply power, of course, it also can be used as prime unit to supply power. I recommend you a supplier, this is his website www.dieselgeneratortech.com, please visit for reference, they have focused on diesel generator set for more than 40 years.
10/9/2019 3:30:17 AM • Solar Electrical... • Answered on Oct 09, 2019
Which gas tanks are which on my 1972 Dodge Apollo motorhome. Which feeds the generator? How much gas is needed to run the generator ? Also if I put solar panel up how do I hook them up and how many panels are needed?
Before we use diesel power generators, installation and connection should be carried out, installation site should be well ventilated, generator end should have enough air intake, diesel generator end should have good air outlet, sowhat matters should be paid attention to for daily fuel tank installation? 1.We should select a suitable location, the location needs to be safe and fire-proof, and should be placed in a visible place, properly far from the location of the diesel generator set and smoking is strictly prohibited. 2.Special fuel tank base must be built in the tank compartment, so that the tank can be placed on it alone and the interior needs to be filled. Paving the floor with fist-sized pebbles and filling the cracks with yellow sand, which can prevent the diesel oil leaking into the sandstone whendiesel oil leakage appears in the machine room. Even if fire is currently generated, it will not burn, because it has passed through yellow sand. 3.We need to do a good job of fire control measures in the machine room, also need to equip fire extinguishers, gas masks and other items, to ensure that when such a failure occurs, it will not cause harm to our personal safety.
9/30/2019 2:03:12 AM • Solar Electrical... • Answered on Sep 30, 2019
What the best and cheap way to go for electric in a moterhome
unable to answer fixya doesnt do evaluations try looking up consumer report or online search to do comparisons - also take into account your locations - lifestyle-vehicles load input -vehicle -ect
9/9/2019 1:22:00 PM • Solar Electrical... • Answered on Sep 09, 2019
I have a solar charger for an electric fence that has 7000 volts - after I hooked up 4 strands of wire, the charger only has 1000 volts. Any idea what the problem might be?
Likely a wire has escaped an insulator and touching a post or a wire is in contact with weeds.
7/19/2019 9:05:42 PM • Solar Electrical... • Answered on Jul 19, 2019
3answers
Is this for real
Solar generators produce electricity which is proportional to how much money you have.
6/19/2019 2:44:20 PM • Solar Electrical... • Answered on Jun 19, 2019
6 pack solar lights and only one stake to put it in the ground?
It sounds like you purchased a defective item. I would recommend returning the product for another or contacting the manufacturer.
6/8/2019 5:06:19 PM • Solar Electrical... • Answered on Jun 08, 2019
How to fix/wire solar umbrella lights
YouTube has many repair videos.
2/16/2019 1:54:59 PM • Solar Electrical... • Answered on Feb 16, 2019
Do solar panels get weeker over time?
You are correct they do lose the output over time. .Not knowing the specific type or brand of the panels the following is a general over all reply. The manufacturer will give the specific amounts the panels will lose their efficiency. Newer panels I believe will 2-4% the first year then something like 1% per year. Newer panels usually have a life of 20 years. I am not sure about the smaller panels you have but I would guess they may be a little faster especially if your putting them up and down constaly. Also make sure you clean them, that will make a very substantial difference especially since they are smaller in size and I am sure you know that shade on ANY PART of the panel may eliminate total sections of the panel producing power, depending on the type of [panels you have. Also check for scratches where you might be able to light through the panels as that may affect the output. I would suggest a google search for manufacturer and model # and then review the spec sheets for the item. That is were you would find the information.If you don't and the company is still in business send them an email and they will let you know. Good luck.
12/19/2018 9:27:49 AM • Solar Electrical... • Answered on Dec 19, 2018
I have solar panels, a battery and a electric grit connection. In case the grit connection is cut of, do I have power from the solar panels ?
check with you installer but the battery should be running the house and allowing the solar system to work as well
7/29/2018 9:20:13 AM • Solar Electrical... • Answered on Jul 29, 2018
Can some one tell me can I use a 18 volt solar panel to charge a 12 volt battery thanks
Yes, you can. But observe proper polarity and monitor the charging.
7/11/2018 3:28:43 PM • Solar Electrical... • Answered on Jul 11, 2018
2answers
Zareba 5 mile solar fence not putting out power with new battery installed
Any electric fence will have no power if weeds or long grass is up against the fence itself. We even had a big thistle that shorted out our fence and there was no shocking power in the fence itself.
6/20/2018 6:27:02 AM • Solar Electrical... • Answered on Jun 20, 2018
How do I read my new meter that is hooked up to my solar panels?
Interesting question. We have solar too but never got around to learning how to read the meter itself as I usually look at the on line (phone app) for the solar production. Reading the meter can give you the actual amount you will be charged if you have the 1st of the month reading and the end of the month reading. With a bit of math you can subtract the amount your panels produced to the amount you used. That's the basics used on your electric bill. Though they do add in the tax, fuel fee, and Admin charge. The fees are usually only charge if you used power in excess of what you produced. But they will always charge the Admin service fee which is about $18 in Hawaii. I've heard similar (under $20) charges in other states. "888888" is a test mode to check display "001 ######" Lifetime consumption (power used) "071 ######" Lifetime over production(power sent back) "252" The type of service (which is NETMETERING) * Yes, a bit confusing and requires you to gather up your old electric bills to get all the numbers. I generally look on the bill for the daily K-watt usage and compare that to the daily usage. We use 42 Kilo watts per day in our home. If the solar produces 42 K watts today then I have an idea that we produced enough to cover today's power usage. Rainy days will produce less be may be compensated by several sunny days. The summer is always best as the sun shines all the time. No worries. Usually the first year after a new solar installation. The customer will incur some months with a higher bill (but still lower than a non-solar billing). But as the year progresses into the summer (or sunny months) your bills will lower usually to the Admin charge level. It will be higher if you have an under power demand system (or under sized system, BELOW what your normal usage is.) Next year you will probably forget about checking and reading as the bill will settle. The following link will help read the meter: https://www.youtube.com/watch?v=5AbiAGP7X8s Aloha, ukeboy57
5/28/2018 8:01:46 PM • Solar Electrical... • Answered on May 28, 2018
Solar Fan Impressions 3 Speed/4 Wire Ceiling Fan Switch Logo
4 questions posted
Top Solar Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Bob Kirkwood
Are you a Solar Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Solar Electrical Supplies
Most Popular Question
replacing 3 speed 4 wire
  • Electrical Supplies
