20 Most Recent Danby Silhouette Series DBC514BLS 5.3 cu ft Built-in Beverage Center Cooler, LED Display, Lock & Key, Holds 112 Soda / Beer Cans, and 11 bottles of Wine, Instant Rebate Available Questions & Answers
May be both. Is the evaporator blocked or have ice built up on it? If so there could be two reasons for that. Low on freon or not enough airflow inside the cabinet.
Danby Silhouette... | Answered on Aug 09, 2015
https://www.appliancesonline.com.au/public/manuals/GGR475WLPG-Westinghouse-User-Manual.pdf
Kitchen Ranges | Answered Yesterday
Make and model may help you get an answer
Kitchen Ranges | Answered 3 days ago
bad fan relay if not separate can be on control board
Kitchen Ranges | Answered on Jan 12, 2021
Sounds like a oven thermostat- thermometer is bad. You can search your oven model number followed by manual
You can find part numbers and location. Or you can search how to replace thermostat for your stove. Good Luck. and stay safe.
Kitchen Ranges | Answered on Jan 11, 2021
Does the door seem to be closing all the way? I'm thinking that there is a heat sensor that is turning off the oven so that you don't melt the computer board... but that's just a guess
Kitchen Ranges | Answered on Jan 09, 2021
Never EVER use the self clean program. It always breaks the stove! The 650.F is extremely damaging to everything.
Disconnecting from the mains overnight, SHOULD empty the mainboard memory, but yours didn't so you need an engineer callout. It is all done by electronics, sensors and logic boards.
Kitchen Ranges | Answered on Dec 24, 2020
Find the button it should look like a + and it should turn it up and keep hitting the + till it’s at 500
Kitchen Ranges | Answered on Dec 19, 2020
I had the same problem - here was my fix...
If you remove the warming drawer you will see the heating coil underneath the drawer held in place by three c-shaped clips that are screwed to the bottom of the stove. I finally realized the two front clips (open to the front of the drawer opening) had their tops pushed vertical and that was what was blocking the drawer from going back in. I bent and hammered the clips back into shape and also hammered the bottom of the drawer back into shape where I had bent it on the clips. Then was all good following the manual instructions.
From the scratches on the drawer bottom, it looks like the clips were installed that way at the factory. This was the first time I's had the warming drawer all the way open.
Kitchen Ranges | Answered on Dec 16, 2020
most people use a flexible connector tube. always check for leaks. dont wanna blow up the house
Kitchen Ranges | Answered on Dec 05, 2020
Danby Silhouette Series DBC514BLS 5.3 cu ft Built-in Beverage Center Cooler, LED Display, Lock & Key, Holds 112 Soda / Beer Cans, and 11 bottles of Wine, Instant Rebate Available Logo
2 questions posted
Top Danby Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
MODERATOR Canada
MODERATOR Canada
Are you a Danby Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Danby Kitchen Ranges
Most Popular Question
purchased in 2010 temperature doesnt
  • Kitchen Ranges
