20 Most Recent
Parmak Solar Fence Charger Questions & Answers
Charger was working fine but now no longer turns on
If under warranty have it repaired/replaced. If not under warranty then some basic troubleshooting. Most likely a battery issue howerver;
To test the fencer output you can power the fencer from either a standard 6V lantern battery (6V fencer) or a standard 12V automobile battery (12V fencer). You need to rig wiring observing polarity.
To test battery, remove and check voltage with digital volt meter.
A fully charged 6V SLA battery should read 6.2V minimum and a 12V should read 12.4V minimum. If a 6V battery measures 4 volts or less then battery has likely failed. Likewise if a 12V battery measures 10 volts or less it has likely failed. Before replacing a suspect failed battery, connect the battery to any standard 6V/12V automobile charger and see if it will take a charge. After the charging period;
- If battery takes a charge, reinstall back in fencer and see if fencer output is hot. If fencer fails output, repair/replace fencer. Else verify the fencer is charging the battery. While battery is installed in fencer measure battery voltage with a digital volt meter. Typical minimum voltage is 13.5V for 12V and 6.7V for 6V. If fencer fails to meet minimum battery charging voltage, likely the fencer solar charging system has failed, repair/replace.
- If battery fails to charge, likely battery is end of life. However fencer could still not work. Test fencer with alternate power source (see previous tests). If fencer ok, replace battery.
I was given a Parmak fence charger---Model Magnum
hi
i am not aware of a manual that are available for this quite an old unit.
you can test it by using an electric multimeter set the setting on volts / plug in the fence unit switch on hold the meter probes on the out put of the unit them you should have voltage reding
HOT LEAD FROM SOLAR PANEL HAS A ELECTRICAL
Either a voltage limiter (because a solar panel can put out upto 21 volts.... BUT more likely a diode - which prevents the storage batteries from discharging through the solar panels (power goes only INTO the batteries when the diode is working.
Radio Shack will be able to match it if you remove it and take it to them.
Solar pac 12 Battery has
With the fence connected or not?. with; then disconnect and turn it on again . if it works fence problem if not unit problem. with-out; unit problem . most likely PCB
12v solar charger is not clicking when turned on.
disconnect the unit from the fence and turn it on. if the fencer work(ticks, meter moves) then it is a fence issue(short, broken wire). if it doesn't then it is an issue with the unit its self and it will probley need a PCB or service.
Solar pack 12 does not work
well that would need more information. does it: tick, the meter move to the right, put a charge on the fence line. with those clearfication a better idea can be given
