20 Most Recent Kitchen Selectives Kitchen Selective 6 Inch Compact Electric Skillet Questions & Answers
This light is a harvest limit light. This light's primary function is to be on as water contacts the ice thickness probe during the freeze cycle, and remain on throughout the entire harvest cycle. The light will flicker as water splashes on the probe. The lights secondary function is to continuously flash when the ice machine is shut off on a safety limit, and to indicate which safety limit shut off the ice machine. Start up of machine after turned off. !. Before the ice machine starts, The water pump and water dump solenoid are energized for 45 seconds to purge old water from the water trough. This ensures that the ice making cycle starts with fresh water. The water fill valve energizes after 45 second water purge, and remains on until the water level probe is satisfied. 2. to pre-chill the evaporator, there is no water for the first 30 seconds of the freeze cycle. 3. The water pump starts after 30 seconds pre-chill. An even flow of water is directed across the evaporator and into each cube cell.
Kitchen... | Answered 3 days ago
after looking at a lot of the manuals on the web I found that the Williams Sonoma bread maker model WS0598 is the same machine as the Salton Breadman Ultimate. find it at this web site http://www.breadmachinedigest.com/beginners/archive-of-bread-machine-manuals.php select the Salton Breadman Ultimate. The 'light' 'medium' 'dark display on the top instead of the sides but every thing else is the same. I think that is just a control version difference. it still has the funtion and all the rest in the same order.
Kitchen... | Answered on May 18, 2020
did someone help you.. If not, I will look where mine is and mail it to you.
Kitchen... | Answered on May 16, 2020
The servicing guide is usually attached under the unit in a plastic sleeve. You can get to by removing the kick panel on the bottom front
Kitchen... | Answered on May 11, 2020
https://www.youtube.com/watch?v=voJeulTUvVs
You can open it up and remove the piezo buzzer, just did it today. Now the toaster works just like it did before but no annoying beep. Opening the toaster is easy enough, but getting enough clearance to put a knife blade under the buzzer was a challenge because of the angle involved. The buzzer is on the circuit board behind the heat adjustment knob, not on the base plate. See this video for some details on piezo buzzer removal in general: https://www.youtube.com/watch?v=cNZ-w5XYVZ8&t=159s
Again, a straightforward fix that is only difficult in 1. Identifying the buzzer itself and 2. getting a good angle to wedge a blade underneath to pop it off. Good luck
Could be a number of different issues:
1. Switch stuck on warm
2. heating element broken.
3. Thermostat broken
4. Safety cutout activated
Kitchen... | Answered on May 10, 2020
The batter should fill half of an 8-inch loaf pan, or ¾ of a 9-inch loaf pan. If using a glass or a dark metal loaf pan, reduce the temperature indicated in the recipe by 25°F. If baking more than one pan in the oven, make sure that pans are at least 2 inches away from each other and from the oven sides.
https://www.four-h.purdue.edu/foods/Quick%20bread%20batters%20and%20loaves.htm
Kitchen... | Answered on May 07, 2020
See if it will run for any longer with no dough. If it does then the issue is related to the machine overheating or pulling too much electric current or perhaps there is a torque sensor that is bad or out of adjustment
Kitchen... | Answered on Apr 27, 2020
https://www.lubemobile.com.au/car-repairs/cooling-system/fan-drive-belt.html?gclid=EAIaIQobChMIiL7G4NeF6QIVAoXVCh3nFgaQEAAYASAAEgLd0PD_BwE
Kitchen... | Answered on Apr 26, 2020
Believe this YouTube video can show you the process. Can't testify this is your exact model, but should be close.
https://youtu.be/otalRB9qFL0
Kitchen... | Answered on Apr 23, 2020
Parts and manuals for QVC products are near impossible to find. Its all made on China and have short shelf lives. But, theres still help.
The best place to ask is in the Cooks Essentials Facebook Group. Ask there, may not have your exact model but most have similar controls and cook times.
Ask here:
https://www.facebook.com/CooksEssentials/
Kitchen... | Answered on Apr 22, 2020
There are a couple of spare parts suppliers in the link. In future, please state full name and model as it helps the experts to give you a definitive answer. Google
make model replacement handle
https://www.google.com/search?ei=8s0rXNn9Ns26ggfWhZPACg&q=waffle+iron.+model+%23245+parts+manual
Kitchen... | Answered on Apr 21, 2020
ebay and other online places are sellers of
mellerware 26550 parts
the drive belt is available new
Kitchen... | Answered on Apr 20, 2020
Took mine apart and put it back together. Lined up the plate under the spinner cap and now it is working.
Kitchen... | Answered on Apr 19, 2020
https://www.youtube.com/watch?v=OWz7Cofdwow
https://www.cnet.com/products/soundstream-vrn-74hb-navigation-system-display-7-in-in-dash-unit-full-din/
Kitchen... | Answered on Apr 12, 2020
You have to disassemble the whole machine. Start from the top, remove the lid, take out all the visible screws. Remove the buttons/controls and disconnect the wires (these will be the only ones you will have to disconnect). Next, remove the bottom screws holding the case to the base, then the base itself. You have to remove everything but the motor and circuit board. Then the bottom cover will come off and you can replace the belt. Just did it on mine. A long magnetic tip Philips screwdriver is all you need.
Kitchen... | Answered on Apr 11, 2020
Kitchen Selectives Kitchen Selective 6 Inch Compact Electric Skillet Logo
0 questions posted
Top Kitchen Selectives Kitchen Appliances - Others Experts
Marvin
Marvin
Irene Tulloch
john h
Are you a Kitchen Selectives Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Kitchen Selectives Kitchen Appliances - Others
Most Popular Question
need one leg model p100 or sk 8 s
  • Kitchen Appliances - Others
