20 Most Recent Leviton 1755 Triple Rocker Switch Decora Questions & Answers
Not sure from your description.
Copy following link:
http://waterheatertimer.org/How-to-wire-switches.html#triple
Add a comment for follow-up
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Leviton 1755... | Answered on Mar 24, 2013
1) Copy following link to see wiring diagrams:
2) There are two basic wiring type, depending if power wire and neutral arrive in switch box first, or power wire and neutral arrive in ceiling box.
3) Most homes, the power wire is in ceiling box.
In this case, a minimum of 4 wires are needed between ceiling box and switch.
Leviton 1755... | Answered on Dec 09, 2012
The switch that you have works like 3 seperate switches. most of these switches will have gold screws
on one side and silver screws on the other side, lets say that the left is gold and the right is silver, and
the switch may also have a green screw for ground. your 12/2 with ground is your main hot, you may
want to mark it with a piece of tape, so you know it's the incoming hot. the ground off your hot will tie,
to the green screw on switch and continue and tie to your vent light which should also have a ground
the white coming off the hot is your neutral, it will go straight to your white or whites on your heater.
the black hot wire at your switch will go to each gold terminal on one side of the switch,there are two
ways you can do this, go to one side and just run a jumper, or put one wire on each gold screw and
tie in to your hot-black wire with a wire nut. now for the switch legs, you will need to run from your, switch
to your heater either another pair of 12/2s or a 12/3, each side of the switch that has one silver screw,
it's easier with a 12/3 normally a 12/3 will have a red,black,white,and ground.
top switch red to red on heater,black to black on light and the white blue on the vent,so from your switch
to the heater you would have to run a12/2 you would not use the black only the white and ground.
remember the white-neutral coming from the switch will be tied to all the whites at the vent,light,heater
except for the 10/3. the 10/3 is used stricktly for the switch legs. good luck!
Leviton 1755... | Answered on Jul 10, 2011
You could use 3 brown single-pole despard switches
Otherwise I cannot find source for triple rocker in brown.
Leviton 1755... | Answered on May 09, 2011
Hello sam. the incandescent only notation is there so that you do not use it with fluorescent or the newer compact fluorescent or LED bulbs. The reason for the double-gang wall box is the wiriing code. you aren't supposed to have more than 4 wires in a single-gang box. Often, the double-gang box is used with a single cover plate top plate. Please do follow the electrical code as not doing so can be a hazard and can void your fire insurance. Joe
Leviton 1755... | Answered on May 07, 2011
Hello sandman, STOP!! Dont do anything else until you kill the bathroom breaker in the breaker box
located by your elect meter. Got it off? Now get a shop light, flashlight, even a lamp w/ext cord.
Position the light so you can see the wires coming out of the wall for switch. The black wires are
the hot ones & the white ones are the return(no power) You have wired your new switch incorrectly
causing the breaker to trip. Check how you have wired the new switch. You neeed one black & one
white wire for each function of the switch. If there is a green wire, it,s for grounding the switch.
Some newer switches have install info stamped on the switch. Kinda hard to see sometme.
Let me know. Happy wiring.......................dansky66
Leviton 1755... | Answered on Mar 27, 2011
I suggest you cut 3 pigtails out of your black wire (about 5-6" each and strip them so you can put a nut to tie them all together on the main wire, then do the same for your grounds using green 5-6" strips of wire and then connect all 3 switches with the pigtails to their proper locations. This WILL fix your problem.
Leviton 1755... | Answered on Mar 09, 2010
It's two single pole switches with a removable jumper on one side. With jumper intact, you connect the hot feed to a either screw of the jumper which I belive are brass colored screws.
Then the two induvidual switch poles are the silver screws. Connect fan motor to one and fan light to the other.
If that doesnt work for you, take a picture of the switch and connections and another of wires in fan box and post here.
Leviton... | Answered on Apr 09, 2020
https://www.leviton.com/sites/REST/controller/LCDownloadController/download/DI-000-VPT24-02F-W.pdf?docurl=/en/docs/DI-000-VPT24-02F-W.pdf
Yes, but appears to be non-serviceable... and its probably just a 3.2vdc lithium coin battery inside the case yet they decided to make it so you have to buy a replacement every 10+yrs. Crack it open and see (dill off any rivet heads).
Leviton... | Answered on Feb 18, 2019
what do you know as "regular " bulbs
are they low energy or incandescent
Leviton... | Answered on Oct 11, 2018
Replace it. They fail and and that is not uncommon. good luck
Leviton... | Answered on May 20, 2018
red never connects to black as that is power to neutral if wired correctly
get in a qualified electrician to check the wiring and help you install the unit
Leviton... | Answered on May 01, 2018
Leviton 1755 Triple Rocker Switch Decora Logo
11 questions posted
Top Leviton Electrical Supplies Experts
jdthefixer
Gene Haynes
john h
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Leviton Electrical Supplies
Most Popular Question
12 2 black white ground
  • Electrical Supplies
