20 Most Recent
Leviton Multi Location Remote Switch/plugin 6697-w Questions & Answers
I cannot turn off light that uses a Leviton Cat /no 16400, DHC switch not can i find the receiver box that controls the lights
A Leviton DHC receiver device can look like any other switch or receptacle so if you didn't install it or not provided a map then you'll need to locate it.
Likely the wall switch that originally controlled the light was replaced with DHC device and paired with the 16400 at another location. If you can't identify it, then removing face plates and devices may be the only practical method to locate it.
If your not comfortable with removing devices safely, hire an electrician.
https://www.mc-mc.com/ASSETS/DOCUMENTS/ITEMS/EN/Decora_6375_Catalog.pdf
7/5/2021 2:59:40 PM •
Leviton...
Answered
on Jul 05, 2021
Wiring a leviton 5641 so fan & light turn on separate with red & black wires
the 5641 is a dual switch for three way and single pole. If you want the switches to operate the CF. Connect the power to one of the two screws on the right side as you face the switch. then connect one wire to the screw on the bottom left side. connect the other screw to one of the two screws on the top left. This assumes the Red and Black you mentioned are the switch legs going to the CF.
5/1/2017 3:42:09 AM •
Leviton...
Answered
on May 01, 2017
Wire occupancy sensor to control receptacle
Your description doesn't explain the circuit, the function of the wires or how the switch controls the outlet and whether the switch is a single pole or two-pole switch. Without such details it is difficult to visualise the circuit.
I advise before you go further to test the sensor in a known good and correctly wired outlet using a length of cable and a suitable plug for the outlet. It is possible the unit is faulty. If it functions correctly on test you will need to understand the circuit and the function of the wires before you rewire it to assure success.
4/18/2016 2:23:52 AM •
Leviton...
Answered
on Apr 18, 2016
