20 Most Recent LG LMH2016ST Questions & Answers
We see and repair this a lot. The problem is on the controller assembly.
There is a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
LG LMH2016ST | Answered on Dec 06, 2013
Unplug remove cover and change main Fuse
LG LMH2016ST | Answered on Dec 04, 2013
The fuse is located inside.
LG Microwave... | Answered on Jan 06, 2021
THE HIGH VOLTAGE FUSE IS IN A PLASTIC EXTRUSION NEXT TO THE CAPACITOR AND DIODE.
YOU CAN USE 3 OR 4 STRANDS OF THIN WIRE FROM MULTI STRAND 15A MAINS CABLE. SOLDER IT OVER THE BLOWN FUSE. I HAVE DONE THIS 100'S OF TIMES.
LG Microwave... | Answered on May 18, 2020
It's most likely your door switch. I have the same problem and was told that. I'm not 100% certain, but will take a look at mine and let you know.
LG Microwave... | Answered on Oct 22, 2019
What is it that you are losing ? You can set the power level by using the marked touchpads on the touchpanel, much like setting the volume on a TV. If you do not change the power setting and it is taking a long time to heat things or intermittently fails to, that is usually a sign that the Magnetron has reached its use by date and needs to be replaced. Not always an economical proposition unfortunately as spare parts are often exorbitantly priced.
Before removing the cover of the oven in attempt to carry out any maintenance such as replacing the Oven cavity lamp, make sure the oven is disconnected from the power point ! The voltages in a microwave oven ARE LETHAL !
LG Microwave... | Answered on Oct 18, 2019
turntable drive may be fouling on cabinet.
Take out the table and see if it is still slow. To centre the drive- take the panel off the bottom, you may have to cut the metal the first time
LG Microwave... | Answered on Aug 05, 2019
take cover off there are plastic catches who could have wear and tare
LG Microwave... | Answered on Jul 16, 2019
First, check your users manual for proper programming functions. Then either return the oven to the dealer for a replacement, if their policy allows it or contact a factory authorized dealer to service it under the warranty policy.
LG Microwave... | Answered on Jul 01, 2019
try this manual i found
https://www.manualslib.com/manual/765799/Lg-Lmv1683st.html?page=34
LG Microwave... | Answered on Apr 22, 2019
Disconnect power and wipe down with vinegar and baking soda solution. Then plug in and heat the same solution for a minute or two. This should take that smell away.
If you’ve found this helpful, please click the green “helpful” icon. If you have 20 seconds please leave a few words as a review or recommendation! Also, follow me for more answers to everyday issues, I’m all for saving you money and making the most of your time! Thanks and have a great day!
LG Microwave... | Answered on Apr 04, 2019
LG LMH2016ST Logo
Popular Tags
5 questions posted
Top LG Microwave Ovens Experts
Sheldon Dedek
Randy Schumann
Randy Schumann
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
LG Microwave Ovens
  • LG Microwave Ovens
Most Popular Question
lg lmh2016st microwave shorted out after
  • Microwave Ovens
