20 Most Recent
Leviton Anywhere Switch - 6696-W - White Questions & Answers
6696 Decora Anywhere Switches triggered by other signals
These switches have an RF operating range of about 50', according to the manufacturer's spec. It is unlikely the neighbors are tripping them. Look around your neighborhood for a ham or CB antenna. That could do it.
Also, these switches run through the AAA batteries pretty fast. You might check them.
50' is not much range for an RF signal. You may take a look at Insteon, which have about a 200' range. Also, they create a "dual mesh" signal by mixing RF with the electrical current in the lines in your house.
I cannot turn off light that uses a Leviton Cat /no 16400, DHC switch not can i find the receiver box that controls the lights
A Leviton DHC receiver device can look like any other switch or receptacle so if you didn't install it or not provided a map then you'll need to locate it.
Likely the wall switch that originally controlled the light was replaced with DHC device and paired with the 16400 at another location. If you can't identify it, then removing face plates and devices may be the only practical method to locate it.
If your not comfortable with removing devices safely, hire an electrician.
https://www.mc-mc.com/ASSETS/DOCUMENTS/ITEMS/EN/Decora_6375_Catalog.pdf
7/5/2021 2:59:40 PM •
Leviton...
Answered
on Jul 05, 2021
