20 Most Recent Igloo Cooler Igloo - 5.2 Cu. Ft. Chest Freezer - Seashell White Questions & Answers
It may be on "superfreeze", if there is a yellow light, or it may be set for too low a temperature (try setting the thermostat down to 1 or 2). Check the condenser is clean, and fan working if it has a fan, Check lid is closing properly and the ambient temperature isn't too high.. Lastly, if all else working correctly, suspect short of refrigerant.
Igloo Cooler... | Answered on Apr 30, 2014
Clicking sound is overheat at the compressor. There is a device called a Clixon that is cutting and restarting. Remove covers and clean the condenser grill with a vacuum cleaner and brush.
Freezers | Answered on Oct 18, 2020
these units are usually set up to have the beater rotate in a clockwise direction facing front. If they get stuck, it is usually due to excessive wear or the hexed end has been lubed and has created a suction seal in it's counter part. Try rotating the beater in a counter clockwise direction while holding the drive wheel pulley stationary. Be sure to unplug unit first. this has worked for me in the past but can be very difficult at times.
Freezers | Answered on Oct 09, 2020
Too high of water pressure letting in more water then it can drain off. Try turning down the water first
Freezers | Answered on Sep 28, 2020
either a t-stat issue or if it does not run for more than a few seconds, your compressor is done for.
Freezers | Answered on Sep 15, 2020
I Need two panels replaced on my Walkin Cooler, is there anyone that cacn give me a quote/price for this repair
Freezers | Answered on Sep 13, 2020
Could anybody please tell me what the colored bottons for this freezer mean. I just got one second hand, plugged it in and there is a red light on. There is also a botton with an S and a circle with a line. I'm guessing that might be on botton but I don't know for sure. It hanks to anyone willing to help!! :)
Freezers | Answered on Sep 09, 2020
Could you comment below with more detailed photos of the back of the orange switch and any other bits with it. If the switch isn't broken It might just 'click' back in. I don't know without better images.
Freezers | Answered on Aug 25, 2020
There are video's on google that have trouble shooting for Igloo ice maker types and for the Igloo ice company and YouTube.
Freezers | Answered on Aug 05, 2020
Question posted under freezers but appears to be Ameriwood Industries furniture.
If you can identify the model number, you can download a free manual from Ameriwood Industries, which has a contact phone number to call for another model if that is different model furniture.
Example with telephone number:
https://www.ameriwoodhome.com/eng/AmeriwoodFiles/ProductDocuments/AmeriwoodFiles/ProductDocuments/19452_B345531309KP00%20instruction%20manual.pdf
https://www.ameriwoodhome.com/eng/instructions
Freezers | Answered on Jul 01, 2020
Hi I have the same problem,
did you get an answer to your question..?
Freezers | Answered on Jun 15, 2020
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Igloo Cooler Igloo - 5.2 Cu. Ft. Chest Freezer - Seashell White Logo
7 questions posted
Top Igloo Cooler Freezers Experts
Bill Boyd
Renee Knafel-Bullock
J Rosado
Are you an Igloo Cooler Freezer Expert? Answer questions, earn points and help others
View Most Popular
  • Igloo Cooler Freezers
Most Popular Question
igloo chest freezer 7 2 cubic ft seems
  • Freezers
