20 Most Recent Electric Intermatic T171 24 HOURS 40 AMPS 125 VAC 1 SINGLE ELECTRIC TIMER SWITCH Questions & Answers
this is a link to the wiring diagram, hope this helps, glad to help you more txt 865-888-1220
https://www.intermatic.com/-/media/inriver/10157-9158.ashx/T171-Instructions-EN
Electric... | Answered on Jul 06, 2017
815-675-7000
Electric... | Answered on Jul 15, 2015
That kiln requires a 30 amp circuit, minimum. 24 amps x 125%= 30 amps per National Electric Code (NEC).
Without more info, I'll need to make a few assumptions. For the sake of estimating the cost I'll present the following scenario:
1...The distance from your electric panel to the pergola is approximately 100 feet.
2...The circuit will be underground. I'll assume that you will be able to hire someone to dig an 18 inch deep trench from the electric panel to the pergoda for $10 hr. While this should only take 3 or 4 hrs, depending on soil conditions, it could take all day. So I'll assume $80 for this.
3...This will be a 240 volt, 30 amp circuit (see why below).
4...Since you posted under the Intermatic T171, and since that is a 120 volt timer, that the kiln is 120 volts.
5...Unless the pergoda is fully enclosed, NEC still requires a weatherproof installation.
For starters, I don't recommend a 120 volt kiln. Most people I've known who had a kiln always seemed to want a bigger one ;-) Again, I'll do the estimate for a 240 volt, 30 amp kiln, as the price difference compared to a 120 volt circuit is about the same.
Also, I strongly recommend using 3/4 inch PVC conduit as opposed to 1/2 inch PVC or UF (direct burial) cable. 3/4 inch conduit doesn't cost much more than 1/2 conduit and will allow you to install wire up to #6. UF cable, in my opinion, is out of the question because if you ever decide that you want a larger kiln the direct buried UF cable is _not_ easily replaceable. A conduit and wire installation is about the same price as UF anyway.
Here's the breakdown (US dollars):
$ 10 - 30 amp, 2-pole circuit breaker
120 - 300 feet of #10 THWN COPPER wire (40 cents a foot)
20 - 1 bundle (100 feet) 3/4 inch PVC conduit
10 - 3/4 inch PVC elbows, fittings, straps
20 - Weatherproof box and weatherproof cover
+15 - 30 amp receptacle
______
$195
+100 - 2 hrs labor @ $50 hr. (possibly 3 hrs.)
______
$295
+80 - labor for trench
______
$375
+140 - Intermatic T172R (weatherproof) 240 volt timer
______
$515
Other considerations are that, if indeed, the circuit is 100 feet, you should consider using a #8 THWN COPPER wire to account for voltage drop (add $60, @ 60 cents a foot) Using a #10 wire at that distance may not allow the kiln to get to the desired temperature.
If you are anticipating things like lights, 120 volt receptacles, fans and such, the best way to do all that is to install a subpanel at the pergoda.
That should get you in the ball park as far as price. Of course, you can make adjustments accordingly. Remember that prices can vary greatly depending upon geographic location. Also, if you call a contractor for an estimate, _after_ they give you the price, _then_ ask how much they will knock off if you dig the trench.
A contractor price of $600 would not be unreasonable.
Hope this helps.
Electric... | Answered on Jun 02, 2010
The 2 silver stops with thumb screw are the stop & start indicators. Loosen thumb screws adjust start & stop times. Tighten.
Electric... | Answered on Nov 04, 2009
Insure the motor wires are hooked to the line in and nuetral posts of the timer. If they are and the timer can be triggered manually then the motor is burned out. If the timer cannot be triggered manually check the breakers at your electrcal panel to see if the one of them may be tripped that supplies the power to the timer.
Good Luck
Electric... | Answered on Dec 04, 2008
When you say breaker, presumably you refer to an RCD?
The residual current device will trip if the amount of current in the hot wire does not equal the amount of current in the neutral or return wire. This means some current is leaking away which means the chainsaws might have developed a potentially dangerous fault or might just be the result of an excess of damp sawdust entering the motor housing through the vents - or damp has entered the tools by other means.
I find a compressed airline useful for keeping power tools internally clean and dry.
Electric... | Answered on Feb 10, 2020
You need to use rated breaker and did you find a fault for why the breaker shorted?
Electric... | Answered on Dec 21, 2019
In the electric windows of - what - ?
Electric... | Answered on Nov 28, 2019
It cannot be connected to 120 volt ... this is a 12 volt photoeye that integrates into the screw terminals on power pack.
Following link has some basic information for connecting the photoeye
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#troubleshoot
Electric... | Answered on Oct 28, 2019
Connecting 12 batteries in series would give slightly more than 61 volts. Considering that under load voltage will drop then it should be ok. Breaker goes between battery and motor on positive wire.
Electric... | Answered on Oct 14, 2019
Hi!
We help people repair their Clarke Generators. You can find testing procedures here: https://www.generatorguru.com/contact-us/
We also hold all the parts possible for all the Clarke Generators and have a "Parts Search Service" if the part is not listed on our site. Check us out on our site.
Parts Spares for Generators and Small Engine Machinery
Electric... | Answered on Sep 13, 2019
either short or failure of gfci
Electric... | Answered on Jun 08, 2019
Tip
Repair broken power cord
I have a 50-ft power cord for my electric pole saw. In an accident, the saw cut the power cord. It's long cable and I want to save it. My method keeps the cable lean and retain it's strength. It's not water-proof, but I never use a pole saw in a rainy day.
on May 31, 2019 | Electrical Supplies
If you make your point of reference the flywheel (starter side) of the motor then rotation is clockwise. If your point of reference is the alternator or the end opposite the motor flywheel, then it will be CCW.
Electric... | Answered on Apr 26, 2019
If you use a car battery you cannot go wrong. Jumper a car battery!
Electric... | Answered on Apr 10, 2019
Electric Intermatic T171 24 HOURS 40 AMPS 125 VAC 1 SINGLE ELECTRIC TIMER SWITCH Logo
6 questions posted
Top Electrical Supplies Experts
Fahr Quad
Muntejaya Ginting
Muntejaya Ginting
epangan29
Are you an Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
Electric Electrical Supplies
  • Electric Electrical Supplies
Most Popular Question
want connect single phase 24 amp kiln
  • Electrical Supplies
