20 Most Recent Heavy Duty Intermatic Wall Switch Timer E1020c Safe Questions & Answers
2answers
OLD wall timer Model E1020 ticks really loud
You probably can't get the existing mechanical timer to operate any quietier, since it's old and likely starting to wear out. You can either swap the timer out for a new automatic digital timer, or install a standard single pole switch in its' place.
I believe the code you refer to regarding the fan having to be wired onto a timer switch was a local requirement from many years ago.
Some local jurisdictions have impossed more stringent requirements, but frankly, having an exhaust fan is normally a good idea. If the fan is vented into the attic space, it can cause some serious problems in cold weather with condesation of the warm, moist exhaust air.
Building Code requires that bath fans be piped/vented to the outside of the house and not into the attic space.
There are newer preset timer switches that will turn on the exhaust fan for a fixed amount of time, based on which button you push. These are great as they will run the fan long enough to remove condensation from showers, etc.
If you're going to replace the timer, disconnect or turn off the breaker or power to the switch. Then simply install a new timer or switch by connecting the black supply wire to the bottom of the single pole switch, or to one of the black leads of the timer. Then connect the black wire going to the fan to the top screw on the single pole switch, or the other lead on the new timer. The white (neutral) wires should already be connected with a wire nut inside the box. Connect the ground wire to the ground wire in the box and if the switch box is metal, attach the ground wire to the box with a green grounding screw too.
You can now operate the fan with either a manual on/off switch or the new digital timer, whichever you chose to install.
10/29/2018 7:31:45 PM • Heavy Duty... • Answered on Oct 29, 2018
Can't figure out how to set the times to turn
Remove dial from body of timer.
So now the timer is apart in 2 pieces.
Silver ON trippers and brass OFF trippers can be removed.
Place trippers in times you want timer to operate.
OFF trippers have to be at least 2 hours apart.
ON trippers have to be at least 2 hours apart
Minimum on-off function is one hour
Snap timer back together.
Tripper rotates around with dial.
When tripper contacts on-off lever, it physically moves lever like turning on light switch.
ON tripper moves lever one direction.
OFF tripper moves lever opposite direction.
Manual E-1020
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/e1020%20-%20english.ashx
12/11/2010 11:20:39 PM • Heavy Duty... • Answered on Dec 11, 2010
How do you set this timer
http://www.intermatic.com/products/timers/in-wall%20timers/24-hour%20mechanical%20time%20switches.aspx
Timer shown is E1020 or E1010
This timer wires into a wall box
Grasp time dial firmly and pull until it comes free from timer.
Remove all silver ON trippers and brass OFF tripper using pencil or paper clip
Program the timer by inserting trippers
The minimum set time for this timer is 1/2 hour
OFF trippers should be spaced at least 2 hours apart from another OFF
ON trippers should be spaced at least 2 hours apart from another ON
Push time dial back onto timer
Current time lines up with time line located at top of timer dial
Next to the time line is the manual override.
Use manual override to reverse the timer program, so if lights are OFF, manual override will turn them ON.
10/29/2010 1:12:30 AM • Heavy Duty... • Answered on Oct 29, 2010
How to you adjust the timer?
the two small plastic arrows will slide in and out for the different times
12/5/2009 1:07:27 AM • Heavy Duty... • Answered on Dec 05, 2009
I have Intermatic E1020C timer and it wont stop ticking
Timers like this are powered by a battery or ac power, the battery one is easy "yank it out", as for ac powered that's a bit harder and if you don't feel comfortable working with live electric stop here...
Now if your still with me, if it's ac it is powered from somewhere, if you can find a breaker that controls it that would be good. Shut off the breaker, disconnect the wires from the timer motor wire nut them then tape the wire nuts and turn the breaker back on, Your done...
Now if you cant find the breaker it's a lot harder, you will have to cut the wires "HOT" this means good high voltage cutters and one wire at a time, please don't touch the end of the wires or the metal part of the wire cutters. It can be done if your careful.
Same end result though, once cut wire nut and tape each wire before going on.
Good luck...
Tim
3/24/2009 9:50:07 PM • Heavy Duty... • Answered on Mar 24, 2009
Manual for scorpion sl2800 generator
Yes
4/9/2024 2:32:16 AM • Electrical... • Answered on Apr 09, 2024
2answers
My conlog meter is showing the rfcon error please what do I do
No connecting to your utilty company in South Africa. Just FYI, we are a North American site and my not always have the answer, in this case we do Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error-cant-do-anything-on-the-gadget-please-help-on-how-to-re/962048393965724/ Quoting from link above: "Conlog Hi Ola-daniels, Please see below steps to assist with RFCON error : * Press the Back arrow on the keypad - this step is to refresh the UIU ( the device) * Type # 75 # - this is to check the signal strength If it does not go back to the normal display *Type # 80 # - this is to refresh the meter Then lastly you can repair the meter and the UIU by # 36 # The above steps will work better if you are outside the house because the meters uses the radio frequency connection The above error will occur in instances of bad weather conditions or if there is load shedding or power failure If the problem persists after trying the above you may contact the municipality or the service provider."
SOLVED: How do I clear up the rf con error on my meter ...
https://www.fixya.com > ... > The
May 7, 2020 - How do I clear up the rf con error on my meter because I want to ... Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error- ... Hi Ola-daniels, Please see below steps to assist with RFCON error : ... shut down the energy alimentation for 2 minute ,but if the defect persist error it show again. SOLVED: Pole meter conlog rf con meter keep on freezing ... Jan. 10, 2017 Meter reading shows rF CON instead of units available - Fixya Jun. 24, 2018 SOLVED: Good day my conlog ip54 elecricity meter showd ... Oct. 6, 2018 SOLVED: Rf con error - Fixya Jun. 20, 2020 More results from www.fixya.com
Please Help With My Conlog Prepaid Meter - Technology ...
https://www.nairaland.com > please-conlog-prepaid-meter
Aug. 6, 2020 - ystar: If the conlog meter is showing rf-Con, it means power supply doesn't reach the meter at all its either Loss of phase from the transformer or a loose contact ... How Do I Load The Activation Token On My Conlog Prepaid ... Mar. 17, 2020 I Need A Technician To Fix This... - Nairaland / General - Nigeria Jul. 22, 2019 I Need Number Codes To Reset Memmcol Prepaid Meter ... Jan. 11, 2019 More results from www.nairaland.com
3/24/2024 3:42:46 AM • Electrical... • Answered on Mar 24, 2024
Wiring 3 lights 3 separate switches
Consult a qualified electrician.
3/23/2024 7:13:23 AM • Electrical... • Answered on Mar 23, 2024
Kawasaki GA1400A Generator. It starts fine, 12 volts okay, but no 230 volts.
Question edited for clarity. Question moved from Motorcycles to Generators category. Some help in the link, but not as much as I would like https://www.google.com/search?q=Kawasaki+GA1400A+no+230+volts+output ..
2/11/2024 5:52:06 AM • Electrical... • Answered on Feb 11, 2024
GE outdoor 200A fusible disconnect can not stay on position, how to fix this issue
It has a cantilever snap action. Either the spring has detached, broken, disabled or unit is otherwise damaged. Heat, water, rodent, etc damage. Replacing the unit is most likely your only option.
2/9/2024 12:37:45 PM • Electrical... • Answered on Feb 09, 2024
What are the valve specs for a kubota av3800 generator
I want PDF AV 3800 Generator
2/8/2024 2:59:27 AM • Electrical... • Answered on Feb 08, 2024
Can i use this tester to check for any live wires. im installed a new light fixture on my porch from existing wiring but lights not tuning on
However, I can provide guidance on using a basic voltage tester to check for live wires when troubleshooting a light fixture installation. Using a Voltage Tester: Non-Contact Voltage Tester: If you have a non-contact voltage tester, it's a handy tool for quickly identifying live wires without direct contact. Hold the tester close to the wire insulation or the terminal screws, and it should indicate the presence of voltage without making physical contact. Contact Voltage Tester: If you have a contact voltage tester, make sure it's designed for the voltage level you're working with (e.g., 120V for residential electrical systems). Turn off the strength to the circuit on the circuit breaker or fuse box. Safety First: Always prioritize safety. Make sure the power is turned off before working on any electrical components. Test the Tester: Test the voltage tester on a known live circuit to ensure it's functioning properly. Check the Wiring: Once confirmed, turn off the power to the circuit you are working on. Use the voltage tester to check each wire connected to the light fixture. Verify that there is voltage on the wires. Neutral and Hot Wires: Typically, a light fixture will have a hot wire (usually black) and a neutral wire (usually white). Make positive each wires are linked properly. Ground Wire: Check for a ground wire and ensure it's properly connected. Some light fixtures may have a green or bare copper wire for grounding. Switch Position: Ensure that the wall switch controlling the light fixture is in the ON position. Bulb Check: Confirm that the light bulbs in the fixture are working and properly installed. Circuit Breaker Check: Double-check the circuit breaker or fuse for the lighting circuit to make sure it hasn't tripped or blown.
1/22/2024 4:17:43 PM • Electrical... • Answered on Jan 22, 2024
I have a onan 4000 LP generator when I try to start it it starts and then goes dead?
Here are some common troubleshooting steps to help you identify and potentially resolve the problem:
  1. Fuel Supply:
    • Check the LP (propane) fuel supply. Ensure that there is enough propane in the tank.
    • Check for any obstructions or kinks in the fuel line.
  2. Air Intake and Exhaust:
    • Make sure the air intake and exhaust are not blocked. Lack of proper ventilation can cause the generator to shut down.
  3. Choke Position:
    • Check the position of the choke. If it's set to "Choke" for starting, make sure to gradually move it to the "Run" position once the generator has started.
  4. Fault Codes or Indicator Lights:
    • Look for any fault codes or indicator lights on the generator control panel. These can provide clues about specific issues.
  5. Oil Level:
    • Check the oil level in the generator. Some generators have a safety feature that shuts them down if the oil level is too low.
  6. Spark Plug:
    • Inspect the spark plug for fouling or damage. If needed, clean or replace the spark plug.
  7. Fuel System Issues:
    • Inspect the fuel system for any leaks or issues. LP generators may have a fuel filter that needs to be checked and, if necessary, replaced.
  8. Carburetor:
    • The carburetor may need cleaning or adjustment. If it's clogged, it can lead to stalling issues.
  9. Battery Voltage:
    • Ensure that the generator's battery has sufficient voltage. A weak or dead battery can affect the starting process.
  10. Generator Load:
    • If the generator is under a heavy load, it may shut down. Try starting it without any load and then gradually add loads.
1/22/2024 4:11:03 PM • Electrical... • Answered on Jan 22, 2024
Heavy Duty Intermatic  Wall Switch Timer E1020c Safe Logo
Popular Tags
6 questions posted
Top Heavy Duty Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Heavy Duty Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Heavy Duty Electrical Supplies
Most Popular Question
old wall timer model e1020 ticks really
  • Electrical Supplies
