20 Most Recent Electric Superwinch LP8500 Series Utility & Off Road Winch LP 8500 12 Volt DC Electr Questions & Answers
Here is a sample of how to wire a winch. I have built my own box with relays to swap the power for reverse etc I'm not sure if you have to buy an extra kit where someone has done the work for you or not. It looks neater when purchased. Click here
Electric... | Answered on Nov 26, 2013
This may help (or maybe not):
The Black wire is the ground wire, and the other two are considered Hot wires, and their
order does not matter - they carry 240 Volts AC.
So, once you identify which terminal on the solenoid is ground, connect Black to it, then just hook up the remaining two Hot wires in any order.
Electric... | Answered on Jul 04, 2011
Not only do you need a 12 volt supply (13.8V) to operate this winch, but you also need a.) wire large enough to carry the electrical load, and b.) a power source that has the necessary current (amps) to turn the motor.
If you have wires that are too small, they will heat up and not be able to deliver the current (amps) required by the motor. If your power source is to small - it can not supply the current required. The result of either conditions is "voltage drop". This can be explained the same way your car needs a 12 volt car battery to start. If that car battery was dead, you couldn't connect eight "D" cell batteries (8 x 1.5volts = 12 volts) together and attach to the car's battery cables and expect it to start. This is because the amount of current available in the car battery is hundreds of time greater than eight "D" cell batteries - even though when the D cells are connected in series - both systems deliver 12 volts.
If neither of the above conditions is present, then there could be an electrical problem with the drive motor itself. This could be a shorted / melted winding or other electrical connection that is not right, even if the drum spins freely.
Electric... | Answered on Apr 04, 2011
If the relays constantly click, your motor is shorted out and bad causing your thermal breaker to trip and open the relays. You will have to replace the motor.
Electric... | Answered on Mar 14, 2011
It sounds like you have broken a pinion tooth. Remove the screw from the end housings and open to inspect the drive gears. Parts can be purchased from Superwinch for these or off e-Bay.
Electric... | Answered on Jan 24, 2011
Take your voltmeter and verify your voltage at the switch. If it is 11.5 or better, try reversing the motor. Reverse direction requires less ampreage to run and should work fine, then try forward or wind.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Electric... | Answered on Nov 04, 2010
I am wiring a Superwinch 4500 to my Yamaha Rhino.
Problem the two red wires go to the key switch.
Do they just splice into the 12 wire ?
Electric... | Answered on Sep 21, 2010
When you say breaker, presumably you refer to an RCD?
The residual current device will trip if the amount of current in the hot wire does not equal the amount of current in the neutral or return wire. This means some current is leaking away which means the chainsaws might have developed a potentially dangerous fault or might just be the result of an excess of damp sawdust entering the motor housing through the vents - or damp has entered the tools by other means.
I find a compressed airline useful for keeping power tools internally clean and dry.
Electric... | Answered on Feb 10, 2020
You need to use rated breaker and did you find a fault for why the breaker shorted?
Electric... | Answered on Dec 21, 2019
In the electric windows of - what - ?
Electric... | Answered on Nov 28, 2019
It cannot be connected to 120 volt ... this is a 12 volt photoeye that integrates into the screw terminals on power pack.
Following link has some basic information for connecting the photoeye
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#troubleshoot
Electric... | Answered on Oct 28, 2019
Connecting 12 batteries in series would give slightly more than 61 volts. Considering that under load voltage will drop then it should be ok. Breaker goes between battery and motor on positive wire.
Electric... | Answered on Oct 14, 2019
Hi!
We help people repair their Clarke Generators. You can find testing procedures here: https://www.generatorguru.com/contact-us/
We also hold all the parts possible for all the Clarke Generators and have a "Parts Search Service" if the part is not listed on our site. Check us out on our site.
Parts Spares for Generators and Small Engine Machinery
Electric... | Answered on Sep 13, 2019
either short or failure of gfci
Electric... | Answered on Jun 08, 2019
Tip
Repair broken power cord
I have a 50-ft power cord for my electric pole saw. In an accident, the saw cut the power cord. It's long cable and I want to save it. My method keeps the cable lean and retain it's strength. It's not water-proof, but I never use a pole saw in a rainy day.
on May 31, 2019 | Electrical Supplies
If you make your point of reference the flywheel (starter side) of the motor then rotation is clockwise. If your point of reference is the alternator or the end opposite the motor flywheel, then it will be CCW.
Electric... | Answered on Apr 26, 2019
Electric Superwinch LP8500 Series Utility & Off Road Winch LP 8500 12 Volt DC Electr Logo
30 questions posted
Top Electrical Supplies Experts
Fahr Quad
Muntejaya Ginting
Muntejaya Ginting
epangan29
Are you an Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
Electric Electrical Supplies
  • Electric Electrical Supplies
Most Popular Question
when try use winch all get
  • Electrical Supplies
