20 Most Recent General Electric GE 56941 24-Hour Outdoor Timer Switch Questions & Answers
Manual Ge timer
GE timer manuals appear following link: http://waterheatertimer.org/GE-timers-and-manuals.html
11/3/2019 11:06:04 PM • General Electric... • Answered on Nov 03, 2019
2answers
Where to purchase trippers for GE mechanical time switch model #15163?
This actually a Jasco 15163 and according to www.harwareandtools.com it takes a Jasco 15602 tripper set. This tripper set can be found for online order at http://www.jascoproducts.com/products/pc/Replacement-Timer-Tripper-2-pack-p1089.htm#.U9Ov2bHG-f415602webg2.jpg
3/1/2019 7:12:27 PM • General Electric... • Answered on Mar 01, 2019
0answers
0answers
Can u interupt a timer powered light with a single pole switch?
I think you want a 3-way timer?Either switch or timer can control lightHere is illustration what I think you have wired, with link to 3-way timers.http://waterheatertimer.org/Timer-with-remote-control.html#switchhttp://waterheatertimer.org/images/Timer-and-switch-400.jpg If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
10/21/2012 11:12:32 PM • General Electric... • Answered on Oct 21, 2012
How to wire GE basic timer replacing wall sw for outside xmas plug
Timer is not identified.Copy following links for GE timer wiring. http://waterheatertimer.org/How-to-wire-GE-15312-timer.htmlhttp://waterheatertimer.org/How-to-wire-GE-15207-timer.html If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
6/30/2012 8:48:11 AM • General Electric... • Answered on Jun 30, 2012
How to wire GE timer 15070
Copy following link for timer wiring.Your box does not have neutral wireThe GE 15070 7-day timer wires same as GE 15312 7-day sunsmart timerhttp://waterheatertimer.org/How-to-wire-GE-15312-timer.html If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
6/30/2012 8:46:21 AM • General Electric... • Answered on Jun 30, 2012
I have a General Electric timer on my water
1) GE timers don't have override switch, but if you raise all the timer segments, the circuit to water heater will be completed.
2) Open link below to identify timer and see wiring diagram, and wiring instructions.
3) Override timer using the wires:
Take a photo of wiring so you can re-wire correctly on new timer.
There is 1 black and 1 white Line wire coming from the breaker.
And 1 black and 1 white Load wire going to water heater.
Connect black Line and Load wires together on same terminal.
Connect white Line and Load wires together on same terminal.
This will complete circuit to water heater and by-pass the timer.
4) Buy new timer at Home Depot.
Reconnect wires on new timer.
Return defective timer in new box.
Keep new timer clean, and swap out whenever needed and give yourself extended warranty.
5) This is the first report of GE timer going bad that I've seen on Fixya.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
9/2/2011 1:50:52 AM • General Electric... • Answered on Sep 02, 2011
I have a new GE
http://waterheatertimer.org/images/GE-15306-wiring-250.jpg
http://waterheatertimer.org/GE-timers-and-manuals.html#15306
GE 15306 is a version of 120Volt Tork 1101 indoor-outdoor timer sold at Home Depot under GE name and number.
You have 2 cables.
One cable comes from Breaker box, and other cable goes to Load (light, fan, motor, pump).
Each cable has black and white wire.
1) Cable from breaker box: Black wire H Hot connects to to terminal L.
Notice there is a metal bridge that connects terminal L and terminal 1.
If metal bridge is missing, use a jumper wire and connect L and 1.
White N Neutral from breaker box connects to terminal X.
2) Cable going to Load:
Black connects to terminal 2
White connects to terminal X.
So both white wires are on terminal X.
7/19/2011 12:15:31 PM • General Electric... • Answered on Jul 19, 2011
How to wire this ge timer 120v
Open following links for GE timers and 15087 wiring:
GE box timers can be wired many different ways to control single-loads, multiple loads, 2-speed motors, 120V, 208V, 277V, 240V, 440V, 24V.
Add a comment and say exactly what you are wiring, and what voltage you are using for more information.
6/24/2011 6:57:58 AM • General Electric... • Answered on Jun 24, 2011
GE 56941 24-Hour Outdoor Timer Switch: how do you wire this GE timer 56922 ?...
Open following links for GE timers and wiring:
6/24/2011 6:53:30 AM • General Electric... • Answered on Jun 24, 2011
My GE 15132 was operating fine for a year but now
Contact Jasco and tell them what you said here.
http://www.jascoproducts.com/contactus/index.asp
Although GE has made high-quality timers for many years, the 15000 series box timers have been on the mass market for a year or so, and there are no replacement parts like available for Intermatic timers.
I tested the GE series and found them to be cheaply made with moveable plastic parts and lightweight overall.
http://waterheatertimer.org/GE-15207-clock.html
6/24/2011 6:45:35 AM • General Electric... • Answered on Jun 24, 2011
How to install timer switch
Open following link to identify timer and see wiring instructions.
GE has a lot of different number for similar-looking timers without any clear way to tell difference.
Add a comment and say if this timer has dip switches, and what screw terminals appear on the wiring block.
6/20/2011 8:16:49 AM • General Electric... • Answered on Jun 20, 2011
GE Indoor Outdoor Timer #
1) If analog dial keeps time, I can only guess that OFF tripper is not in position correctly, or tripper is worn or defective, or that manual override lever is defective. Trippers are made of softer metal so they wear down before other parts of timer.
http://waterheatertimer.org/images/GE%2015306%20Mechanical%20Outdoor%20Box%20Timer-24%20Hour.jpg
2) Buy Tork P47 trippers to replace GE 15306 trippers
http://waterheatertimer.org/Tork-timers-and-manuals.html#Trippers
3) Open following link for GE timer resources:
4) 15306 is heavy-duty indoor-outdoor version of Tork 1800 series or 7200 series 120Volt analog timer that is sold online and at Home Depot under GE brand name.
http://waterheatertimer.org/images/Tork-1800-600.jpg
5) You can buy new timer at Home Depot and return defective one in new package.
6) The on and off trippers are attached to the analog dial.
Dial rotates as time passes.
Trippers make physical contact with the manual override lever. The ON tripper pushes lever one direction and the OFF tripper moves lever other direction.
The override lever rotates a cam located on back of timer that opens and closes electrical contacts.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
6/2/2011 5:57:22 AM • General Electric... • Answered on Jun 02, 2011
GE 15306 timer is brand
Check your wiring.
Check dip switch settings.
Also add a comment and clearly describe your dip switch settings, voltage being used, and exact wiring on each terminal for more detailed help.
Upvote the help.
5/29/2011 11:43:03 PM • General Electric... • Answered on May 29, 2011
General Electric GE 56941 24-Hour Outdoor Timer Switch Logo
Popular Tags
34 questions posted
Top General Electric Electrical Supplies Experts
 Mikey
Mikey
Thomas Perkins
Thomas Perkins
ADMIN Eric
ADMIN Eric
Are you a General Electric Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • General Electric Electrical Supplies
Most Popular Question
new ge
  • Electrical Supplies
