20 Most Recent Tornado 93030 Wide Area Carpetkeeper Upright Vacuum Questions & Answers
To clear the clog, remove the hose and wand from the unit and separate them. The hose is released by pressing the white plastic ring in the housing. The two are separated by simply unscrewing them. Remember this threaded connection uses a left-handed, or reverse, thread. By looking through each of these pieces, the user can ensure they are not clogged. To check the lower hose, it is easiest to lay the unit on its side. Remove the glide sole by turning the yellow turn locks to line up with the slots and then removing the glide sole. Remove the yellow connector the wand was plugged into. You should be able to see the brush through the hose from the rear of the machine.
Tornado 93030... • Answered on Dec 21, 2010
Hi There,
Your Tornado Wide Area vacuum cleaner is actually manufacturered by Powr-Flite. The two companies are sister companies, and owned by the same parent company Tacony.
It sounds like to me that your belt may have broken, or fallen off of the motor shaft. This may explain why the roller brush is not spinning. There is also a reset switch on the machine, on the top (item # 41 in diagram below), you should check the reset switch first. Try pushing down on this switch to see if this will restart your brushes.
If it doesn't, here are instructions on how to open up the belt, and inspect it or replace it if it's broken:
If you need to purchase a new belt, you may contact Powr-Flite at 1-800-880-2913, and request them to send you part number 19802.
Here's links to the instruction manual, and parts diagram for your Tornado, which is the same exact machine as the Powr-Flite model PF2030:
Owners Manual & Parts Diagram
If you have any follow up questions, please don't hesitate to ask using the add a comment form here on the Fixya repair page. If you have any problems ordering from them directly, feel free to contact us, and we'd also be able to provide any parts for you.
Here's how you may contact us:
http://www.govacuum.com/info.html
Thank you,
Chris Jones
GoVacuum.com
Tornado 93030... • Answered on Apr 16, 2010
Can you get to the pump and turn the shaft? 9 out of 10 times the reason that the belt broke was that the pump froze up from residue and rust.
Vacuums • Answered on Apr 28, 2021
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=759260
Generic problem for all Vacuums
Download instruction manual?
Posted by mvassian on Jul 09, 2008
For the Kenmore 3 in 1 deep cleaner model 20 86603--is that possible? Thanks, Myra
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The best place to get this type of information is either the Sears / Kenmore website or to cal the Sears / Kenmore factory to have then either download the information or to send out or mail out the information by US Mail. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
Rubbermaid! I hope Hygiene for All is a double act, spam tag team?
Vacuums • Answered on Apr 26, 2021
Makes no difference. Purchasers decorate how they want.
Yeah, I also have the same problem. I don't know how to fix it, Man
Vacuums • Answered on Apr 21, 2021
I think it is this robot vacuum cleaner: Bagotte BG800 Robot Vacuum Cleaner I am a cleaning enthusiast. I have used many brands of robot vacuum cleaners, but I found that their cleaning effect is almost the same. I suggest that you can choose a robot vacuum cleaner that is cost-effective in the market as your household cleaning tool. Besides, I have a Poodle. She is very lively, always bouncing on my sofa or bed. So my sofa and bed are full of her hair. Animal hair itself tests the suction and cleaning ability of the robot vacuum cleaner more than other garbage and dust, but Bagotte BG800 Robot Vacuum Cleaner does it. At last, maybe this blog can help you: https://bagottelife.com/blogs/tips/what-is-the-best-robot-vacuum-cleaner-for-pet-hair
Some of the Dirt Devils have a reset button on the back, near the bottom. But if the it is getting hot on the bottom, that may mean the motor is trying to run but can't. Maybe something has jammed it. You would have to disasemble it to find out.
Vacuums • Answered on Apr 18, 2021
measure the size and hit home depot
Vacuums • Answered on Mar 27, 2021
Tornado 93030 Wide Area Carpetkeeper Upright Vacuum Logo
Popular Tags
2 questions posted
Top Tornado Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Tornado Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Tornado Vacuums
  • Tornado Vacuums
Most Popular Question
ahve
  • Vacuums
