20 Most Recent Powerstream RP1P Electric Tankless Water Heater, 208/240V Questions & Answers
My tankless RP1P is not heating well the water and
follow this steps and fix it. God bless youTest and replace a heating element:
  1. Turn off power at the electrical service panel and post a sign warning others not to turn it on.
  2. Remove the access panel on the electric water heater.
  3. Disconnect one of the element wires and set a multimeter to RX1000 (resistance times 1,000). Touch one probe to an element mounting bolt and the other to each element terminal screw, in turn. If the tester displays anything but infinity ( open circuit), replace the element.
  4. If necessary, set the multimeter to RX1 and touch the probes to the terminal screws. If there is any resistance reading at all ( closed circuit), then the element is good. If not, replace it. Both upper and lower elements are tested in the same manner.
  5. To remove the element, first drain the heater.
  6. Disconnect the remaining element wire. Remove the mounting bolts holding the element in place. Remove the element.
  7. Replace the heating element with one of the same model, shape, and rating. Make sure you also replace any installation gaskets.
10/21/2013 11:59:54 AM • Powerstream RP1P... • Answered on Oct 21, 2013
Where can I get a Service Manual including error codes, of HITACHI Package unit RUA-30AT3S?
I am not sure they are available to non Hitachi service centres. https://documentation.hitachiaircon.com/glb/en/pac/rua-at3s
3/17/2024 4:06:16 PM • Water Heaters • Answered on Mar 17, 2024
VAILLANT ECOTEC PLUS 831 BOILER , with an error code of F79, which is not in the handbook, its not working at the moment, already had a local plumber out, who didn't know a lot about F79 code
Cannot find the fault code . There are vidoes on u tube saying how to reset thr code By pressing the reset button . If this does not work youcan ccontact vaillent on there web page . I have a mate who works for them i will ask him as well
2/12/2024 9:14:32 PM • Water Heaters • Answered on Feb 12, 2024
2answers
Envirotemp water heater
Do I need to insulate this heater out in the shed? Freezing temperatures
2/6/2024 11:45:03 AM • Water Heaters • Answered on Feb 06, 2024
Remeha avanta plus combi problem
Call a engineer
1/11/2024 7:52:09 PM • Water Heaters • Answered on Jan 11, 2024
What is error code c8 mitsubish heater
The P8 fault can mean many things when it pops up on your Mitsubishi Electric wall controller. The P8 fault is activated when the indoor coil sensor does not change the temperature for a set amount of time after the compressor is (or should be) switched on.
12/26/2023 4:41:20 PM • Water Heaters • Answered on Dec 26, 2023
How to replace digital thermostat on Amtrol boilermate to a manual thermostat
Where does the tube sensor go
12/23/2023 12:54:29 AM • Water Heaters • Answered on Dec 23, 2023
10 year old Richmond 40 Gallon water heater, cannot move knob to ON/OFF or Pilot. Pilot light is out.
call plumber to replace gas valve, it may cheaper replace water heater. gas valve is not DIY
12/1/2023 6:48:46 PM • Water Heaters • Answered on Dec 01, 2023
My boiler doesn,t always switch off when programe is off
test for sticking relay faulty circuit board or faulty stat
10/28/2023 4:42:20 PM • Water Heaters • Answered on Oct 28, 2023
Rival titan floor heater coils don't turn red
Beware when working with electrical equipment. It may cause electric shock. Check the power supply wires, connections with heating coils. If they are ok then possibly heating coils require replacement.
10/17/2023 2:53:24 PM • Water Heaters • Answered on Oct 17, 2023
3answers
Where on a sunday do I find a GS640YBVIT heater?
I would try their website; www.statewaterheaters.com They should show a list of their service agents.
8/28/2023 6:22:14 PM • Water Heaters • Answered on Aug 28, 2023
How do I bleed the pump? It's running but not circulating water after partially draining the hot water heater.
Domestic Central Heating, Dodge Caravan, well pump or a Pool Heater, or something else. All questions need 'make model (what it is)' as first 3 words. With the exception of the Dodge Caravan, pumps have a small bleed screw. Google make model bleed pump or if it is an above ground well pump make model prime pump This is heavily weighted towards vehicles, but you will get the ideal of the power of Google! https://www.google.com/search?q=%E2%80%8Bmake+model+bleed+water+pump ..
5/17/2023 10:56:35 PM • Water Heaters • Answered on May 17, 2023
Towerchron QE2. Timer set up ok. Room thermostat set 25. Timer lights ok at set timings. Boiler will not come on
Call for Service. The timer is fine, the boiler has failed. I presume it is gas fired, which means that only gas registered service techs can work on it.
4/16/2023 10:15:58 PM • Water Heaters • Answered on Apr 16, 2023
Energy smart water heater has start up failure
Energy smart water heater has start up failure problem so how to resolve
3/26/2023 5:11:27 PM • Water Heaters • Answered on Mar 26, 2023
3answers
Richmond water heater 6g40-36f1 lights then goes
Check the thermocouple and the control box.
3/18/2023 6:55:07 AM • Water Heaters • Answered on Mar 18, 2023
Want to see a manual for model 6G40-36F1
I can get the pilot lit but when I turn the water heater on it blows out everything it is a Richmond water heater serial number 6G 40-36f 1
3/4/2023 4:17:19 PM • Water Heaters • Answered on Mar 04, 2023
Powerstream RP1P Electric Tankless Water Heater, 208/240V Logo
1 questions posted
Top Powerstream Water Heaters Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Powerstream Water Heater Expert? Answer questions, earn points and help others
View Most Popular
  • Powerstream Water Heaters
Most Popular Question
tankless rp1p not heating water
  • Water Heaters
