20 Most Recent Bradford White Bradford MI30T6FBN-337 30 Gallon Wa Questions & Answers
1) Just open the following link to identify gas control, and following instructions for lighting each gas control that appear under the gas control that looks like yours.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) Otherwise add a comment and carefully describe gas control valve, and then open link and compare your description to pictures of each gas control valve, and then look below each picture for link that says how to light water heater.
3) Call plumber.or local service technician, or local BW supplier who can recommend technician.
4) Call Bradford White to get recommendation of local technician.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Bradford White... | Answered on Feb 12, 2013
1) Copy following link to identify gas control valve:
2) Add a comment and describe gas control valve, and include if this is on boiler or water heater
1) Copy following links to identify gas control valve and read ignition procedure, and access service manual for your product:
2) Honeywell gas control used on recent Bradford White gas water heaters has red knob that rotates to pilot. Press and hold red knob. Then push red igniter button until status light changes.
Sounds like the TCO is tripping .../. because temperature inside burner is higher than 180°
Replace TCO ... and it problem is not fixed, replace gas control valve thermostat
http://waterheatertimer.org/troubleshoot-gas-water-heater-thermostat.html
Bradford White... | Answered on Oct 02, 2018
Replace the motor
Bradford White... | Answered on Dec 18, 2013
Copy following link for replacing thermostat.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Suggest you might also want to test the elements while power is turned off, just in case the problem is element shorted to ground across metal tank to ground wire.
http://waterheatertimer.org/How-to-test-water-heater-element.html
At least you know the 240volt power to water heater and the circuit breaker are good.
Bradford White... | Answered on Oct 01, 2012
look for display or control board if no buttons then cant adjust
Water Heaters | Answered 2 days ago
Automatic battery chargers have complex circuitry that is difficult to test especially when designed and built in a compact package and repairs are best entrusted to someone geared to such work which is outside the scope of general electronics.
On the plus side, as long as the intelligent circuitry is protected against mains borne surges and spikes the automatic charger is somewhat self-protecting against over stress and will tend not to even attempt to charge a defective battery, a sulphated or overly discharged battery.
I suggest you first check the battery or batteries to ensure they are healthy and have some charge so the charger can "see" them before condemning the charger and also check the connections to the battery that must be virtually perfect...
Water Heaters | Answered on Oct 05, 2020
Depends on the problem you have .if you are unable to fix it the option of calling a plumber is there .
Water Heaters | Answered on Sep 07, 2020
When the noise occurs when there is no hot water being used, it's likely there is a vacuum that's siphoning water away from the unit and causing loud noise and vibration. ... Another common problem that can create noise in tankless water heaters is a dirty flow sensor which controls how much gas is sent to the unit.
https://www.youtube.com/watch?v=Fsb8Wx9PRvY
Water Heaters | Answered on Jun 24, 2020
NO HOT WATER
  1. If the tester indicates there is power to the terminals and the water in the geyser is cold, then the element is faulty. ( ...
  2. If the tester indicates there is no power to the terminals and the water is cold, then the thermostat is faulty.
https://www.youtube.com/watch?v=qCXmyhEY_k4
Water Heaters | Answered on May 06, 2020
Bradford White Bradford MI30T6FBN-337 30 Gallon Wa Logo
4 questions posted
Top Bradford White Water Heaters Experts
Paul Carew
Marvin
Marvin
Are you a Bradford White Water Heater Expert? Answer questions, earn points and help others
View Most Popular
  • Bradford White Water Heaters
Most Popular Question
bradford white defender m 30t6fbn
  • Water Heaters
