20 Most Recent Kenmore series 70 80 90 Washer timer 661649 Questions & Answers
I have a Kenmore 70 series Washing machine top load model 110 serial number 82870120 . where is the lint trap located and how to take out to clean? clothes have a lot of lint after being washed.
It is likely that a tissue or paper product was included with the wash load. The series 70 does not have a lint trap. At the hose connection to the house drain lint has been known to build up restricting the emptying. This buildup would not introduce lint into the washer. If the water temperature is very very cold and you use powder detergent it will not dissolve completely into the water and will leave a white residue on the fabrics. Try running a short load in the washer allowing for ample water to rinse out the machine before the next wash load.
12/28/2015 9:39:05 PM • Kenmore series... • Answered on Dec 28, 2015
How do I clean the filter?
there is NO filter in a washer,use a refresh washer cleaner to smell good,
3/26/2015 8:21:31 PM • Kenmore series... • Answered on Mar 26, 2015
Kenmore 70 washer connector
The water inlet hose? They are a standard fitting, only one type. The only difference is the quality. Buy the best!
1/23/2022 9:11:54 PM • Kenmore Washing... • Answered 22 hours ago
My Kenmore top loading clothes washer stays on sensing and goes no further.
When Kenmore HE Washer is stuck on Sensing Cycle and not proceed to the Wash cycle, most likely one of these 3 parts malfunction: Failed Water Inlet Valve or Inlet Valve Tap is in OFF position. Shift Actuator not able to change position, before Wash cycle. Control Board malfunctioned.
3 Top Reasons Why Kenmore HE Washer Is Stuck On Sensing
Videos as well, it is a known issue https://www.google.com/search?q=Kenmore+top+loading+clothes+washer+stays+on+sensing ..
1/23/2022 7:27:13 PM • Kenmore Washing... • Answered Yesterday
Kenmore 600 triple action washer keeps filling when it's halfway done, why?
possible stuck water solenoid or control board
1/23/2022 6:23:16 AM • Kenmore Washing... • Answered Yesterday
The washer won't agitate at all.
Could be Drive coupling, Clutch dogs or Gearbox. Arrange a service call. They are all messy jobs and need a lot of stripping down and in some cases a special tool. There are ideas in the link. https://www.google.com/search?q=turn+the+bottom+half+of+the+agitator%2C+either+direction ..
1/20/2022 9:04:22 PM • Kenmore Washing... • Answered 3 days ago
Troubleshooting my Kenmore washer
Remove the case and check the balancing springs and dampers. Something has broken.
1/19/2022 1:22:09 AM • Kenmore Washing... • Answered on Jan 19, 2022
How do I tell if the agitator dogs are bad in my Kenmore 400 washing machine?
It won't agitate back and forth. It will either do nothing or it will gently turn one way only.
1/15/2022 12:12:41 AM • Kenmore Washing... • Answered on Jan 15, 2022
Washing machine making funny noise
'Funny noises' are difficult to diagnose, but it could be the gearbox or clutch, or it might just be the belt as the drum isn't turning. There is a belt replacement video in the link https://www.google.com/search?q=Kenmore+Series+90 ..
1/11/2022 11:47:56 PM • Kenmore Washing... • Answered on Jan 11, 2022
I have a Kenmore 592-89047. The hourglass light is always on (never goes out), what ever cycle I chose. For all chosen cycle. Any idea what I need to do?
Try cutting the power to it for an hour. There is a Fixya thread on this machine and one person suggests the dryer probe needs cleaning. https://www.google.com/search?q=Kenmore+592-89047 ..
1/11/2022 6:04:59 PM • Kenmore Washing... • Answered on Jan 11, 2022
How to find water leak under washer
Slide a couple of sheets of newspaper under the washer. Run the washer for 5 minutes and pull the paper out. This will show you the area where the leak is. Wait until the cycle finishes, pull the washer out and lean it against the wall. Have someone steady it whilst you look underneath with a flashlight. Likely to be a loose joint or a perished hose.
1/2/2022 12:55:27 AM • Kenmore Washing... • Answered on Jan 02, 2022
Kenmore HE5T washer door locked light on
The problem has to be the new power source. Something is wrong. Is it grounded. Check for problems there. It's shorting out the machine
12/31/2021 8:06:14 PM • Kenmore Washing... • Answered on Dec 31, 2021
2answers
Error code f33 on an he4t
The F33 error code indicates a pump drive system error. If the pump ohms out correctly & the harness is secure I recommend replacing the CCU (central control unit).
Please see the following image provided for instructions.
http://media.fotki.com/1_p,stwwfrggtqfbrbbxgtqsskgwtqkq,vi/wgtbwqwssxsbwkbdtfwxrbfbddwwf/1/1303472/5961857/image9159087223444281043img-or.jpg
Remember to disconnect power to the washer before attempting access.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
12/29/2021 3:46:16 PM • Kenmore Washing... • Answered on Dec 29, 2021
I have a kenmore top loader. It has a rinse/spin cycle. How do I get it to just use the spin cycle without rinse?
You may be able to turn the water off. Sometimes there is a pressure or flow sensor but that is worth trying. If there is a pressure sensor then there is nothing you can do unless you want to modify the machine
12/11/2021 10:24:45 PM • Kenmore Washing... • Answered on Dec 11, 2021
I have a Kenmore 600s washer and were getting a F5 code with some alarm nopises
Error f5 is due to a fault in the wash temperature sensor sometimes due to a breakdown or a bad connection. On some occasions the resistance may be damaged. Both the sensor and the resistance are in the wash tub. Potential Causes • Check the Water Temperature Sensor, Heating Element and Element Relay • Check connections to the Sensor, Heating Element and Relay
12/10/2021 8:06:09 PM • Kenmore Washing... • Answered on Dec 10, 2021
What does Lo Flo mean on Kenmore front load washer?
https://www.appliancecodes.com/whirlpool-washer-lo%20fl-error-info-7-71/ https://findanyanswer.com/what-does-fl-mean-on-kenmore-elite-washer
12/7/2021 8:40:25 PM • Kenmore Washing... • Answered on Dec 07, 2021
Kenmore series 70 80 90 Washer timer 661649 Logo
Popular Tags
2 questions posted
Dale Copeland
Dale Copeland
Pieter Vleeshouwers
Pieter Vleeshouwers
View Most Popular
  • Kenmore Washing Machines
Most Popular Question
kenmore 70 series washing machine top
  • Washing Machines
