20 Most Recent Polder KSC-310-28 Easy-Read Digital Kitchen Scale, Extra Large LCD Displa, 11Lb 4Kg Capacity, 1/8oz 1gram Increments, Add & Weigh, Auto Off, 4AAA Bat Questions & Answers
Be sure all 3 batteries are fresh and also be sure they are in correctly .positive+ and negative- , to proper placement in machine. Typically the spring contact points go on the flat -end of battery and the + nipple end of battery goes on the solid or button contact on the machine. Spring end contact points on machine may be an actual spring or a raised metal piece either way they are the end that flexes and holds the battery tight against both contact points. Sometimes the spring must be carefully pulled to make it give more holding pressure. Good luck and I always say Google it!
Polder... | Answered on Oct 18, 2017
I am not familiar with the model but I have dismantled a fair number of steam irons - manufacturers are invariably devious in hiding the screws and generally the more modern the iron the fewer are the screws.
Over the years I have needed to prise off various pieces of trim to reveal screws - commonly there has been one revealed by removing the temperature control knob.
The last one was held together by only two screws accessed after removing the rear terminal cover. The cable had to be removed and the terminal screws - then the rear of the upper shell would lift far enough to clear all obstructions and be pushed forward to release the front and then lifted clear.
Irons | Answered on Sep 12, 2020
suspect the heating element has burnt out cheaper to buy new than get fixed
Irons | Answered on Aug 26, 2020
you won't unless you install a switch in line of the power cord. in other words put a switch on the cord. You can get them just about any where ACE walmart Home depot.The reason it's doing that is because the heating element is being told to heat up right away. it's not going to hurt anything. it is a good idea to have a switch though
Irons | Answered on Aug 23, 2020
No screw under my button to reel the cord back in...looks like there is black "gunk" inside the cord storage area...any other suggestions
Irons | Answered on May 22, 2020
The Polti iron is packed with Italian style and its makes ironing a pleasure not a chore. Its a laundry lovers friend and you will save so much time as you breeze through your weekly mountain of ironing with ease. ... One of my most loved features with the Polti is the lock feature at the front of the iron
Irons | Answered on May 18, 2020
Cleaning a Laundry Iron
Get some CLR descaler and mix it to the directions. Turn the iron on and set it to steam. Turn the iron off and put the CLR into it, when it has cooled a little, sit it face plate down in an oven proof dish. Leave it over night. The CLR will drip through and sit in the dish cleaning the inside, and the topside of the sole plate. The next day, fill with water and shake upside down to empty any remaining CLR and scale through the fill hole. Keep filling and shaking to empty until the water comes clean.
If you don't want to use CLR, you can use white vinegar undiluted.
For just the sole plate, you can use oven cleaner, or sit in a dish with household ammonia overnight. Put the dish in a garbage bag to reduce the fumes, or put it in your garage or garden shed.
https://www.fixya.com/support/r26134544-cleaning_laundry_iron
Irons | Answered on May 07, 2020
if you never clean the deposits from the water out then they get all plugged up
Irons | Answered on Apr 28, 2020
check and test switch and wiring
Irons | Answered on Apr 14, 2020
not repairable
junk it and get a new iron
Irons | Answered on Apr 09, 2020
contact the mfg we do not know why it doesn;t work for you,i would suspect the heating element tho
Irons | Answered on Mar 29, 2020
Press the self clean button , hold it there, and gently move the iron to and fro, over the basin or bowel. CAUTION: Keep clear of the escaping water and steam. Water and steam will wash scale and dust through the soleplate, and into the basin or bowl. When the water tank is empty, release the self clean button .
https://au.russellhobbs.com/pdf/19840au_-_colour_control_iron.pdf
Irons | Answered on Mar 25, 2020
Nowadays there are various services for doing such work .You can hire them.There are also leak detection services who can help you in finding the leakages,repairing pipes ,removing mold and cleaning the tank.So it is better to hire them and check your pipes while cleaning.
http://www.allkarepropertydryingout.co.uk/luton/leak-detection-services-london.html
Irons | Answered on Mar 02, 2020
Polder KSC-310-28 Easy-Read Digital Kitchen Scale, Extra Large LCD Displa, 11Lb 4Kg Capacity, 1/8oz 1gram Increments, Add & Weigh, Auto Off, 4AAA Bat Logo
3 questions posted
Top Polder Irons Experts
Colin Stickland
Colin Stickland
Marvin
Marvin
Are you a Polder Iron Expert? Answer questions, earn points and help others
View Most Popular
Polder Irons
  • Polder Irons
Most Popular Question
replaced three batteries in polder
  • Irons
