20 Most Recent Kenmore 30-pint Dehumidifier with Electronic Controls Questions & Answers
I do believe this one of those models that uses one display for both setting of humidity level and the timer , make sure you are viewing the timer function and not the humidity function , this is a very common complaint with these type as many times one sets the on time correct but then sets what they believe to be off time when they really are adjusting the humidity room level , there should be tiny lights that show function you are adjusting
Kenmore 30-pint... | Answered on Jun 06, 2015
580.5451 appears to be the dehumidifier model #
Contact Sears online or by phone:
https://www.searspartsdirect.com/model/3gdb2g701p-000582/kenmore-58054351900-dehumidifier-parts
https://www.searspartsdirect.com/search?q=580.54351
Kenmore... | Answered on Jun 19, 2020
try manufacturer site or online search using make and model
Kenmore... | Answered on Feb 17, 2020
I would suspect the cooling coils have leaked the freon and aren't cooling enough to condense the humidity into water. These units aren't really made to repair unless it's a switch or humidity sensor. The cost to have the leak fixed and freon reloaded would exceed just buying a new unit.
Kenmore... | Answered on Nov 04, 2019
First I'm not a Kenmore Tech.
* Check your warranty and call for service.
*** The following is for information only ***
* I had one of these dehumidifier. I've used both the drain bucket by itself and well as the hose attachment.
* the bucket has a hose cap at the bottom to allow a typical garden hose to be attached. Remove the cap and attach the hose.
* If you want to use just the bucket then you will need to remove the garden hose and re-cap the bucket. Otherwise the water will just drain on the floor. You can find a replacement cap at any hardware or garden shop.
* There is a sensor switch under the drain bucket. This senses if there is a bucket present and it will turn off the unit once it's full of water.
*** The bucket must be present for this dehumidifier to work ***
* You must place the bucket in the right position for the unit to come on. The attached hose must move freely up and down to prevent the bucket from being weighed down and turning off the unit as it thinks the bucket is full. Lifting the hose a bit up and down will give you an idea if it's too heavy.
* Final; there is an adjustment knob in the front to determine how dry the air you want. I've used this unit to dry out wet carpets in a room so it's set at max and usually takes about 1-2 days to dry out a room (in Hawaii with 60% humidity). You will need to set this up and adjust it for your purpose.
Aloha, ukeboy57
I found the following vids on you tube;
https://www.youtube.com/watch?v=VhLv0xR9-Ag
https://www.youtube.com/watch?v=EmWuaIG8fS8
https://www.youtube.com/watch?v=XOh4BztkIEo
https://www.youtube.com/watch?v=Zb2rj-xWE9A
Kenmore... | Answered on Jun 28, 2018
Hello, Mike -
You MAY be able to find the right filter to order for your Kenmore dehumidifier on the website PartSelect Canada:
https://www.partselect.ca/
or on the website Easy Appliance Parts Canada:
https://www.easyapplianceparts.ca/
or on the ShopBot Canada website:
https://www.shopbot.ca/m?q=Kenmore+dehumidifier+filter
Best wishes.
Kenmore... | Answered on Jun 01, 2018
Suggest read the owners manual section for that feature.
Brand new means it's still under warranty.
Kenmore... | Answered on Mar 03, 2018
Do the coils get cold and the unit blow cold air? If not, the compressor is not really working.
Please rate 4 stars if this is helpful. Thanks and good luck!
Kenmore... | Answered on Oct 25, 2017
Did you punch out (or cut) the plug that the hose connects to? If not, its blocking the water from draining to the hose.
Also, make sure the unit is higher than the drain and that the hose is not kinked or clogged.
One open, other closed.
You probably have it set for too high (moist) a setting, so it doesn't need to run long.
Slowly reduce setting to Drier settings to get it to run longer.
Kenmore... | Answered on Oct 03, 2017
Kenmore 30-pint Dehumidifier with Electronic Controls Logo
Popular Tags
1 questions posted
Top Kenmore Dehumidifiers Experts
Marvin
Marvin
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
View Most Popular
  • Kenmore Dehumidifiers
Most Popular Question
dont understand timer kenmore
  • Dehumidifiers
