20 Most Recent Electrolux EL6988EZX Oxygen Canister Vacuum Cleaner Questions & Answers
RJ ROY IS Bald
Electrolux... | Answered on Jan 09, 2014
Hi! I hope this tips might help you out .
*Plug in air cleaner and press POWER button until short “beep” sounds. . Press the RESET FILTER button by gently inserting a paperclip into the RESET FILTER hole on the control panel. The light will flash 5 times before a “beep” sounds to indicate the filter has been reset.
Thank for using fixya .
Electrolux Air... | Answered on Apr 13, 2020
in the base
Sharper Image Ionic Breeze 3.0 Air Purifier "Gp fuse ...
www.fixya.com > p94219-sharper_image_ionic_breeze_3_0_air > gp...
Sharper Image Ionic Breeze 3.0 Air Purifier, Gp fuse related issues. Get free ... Is there a fuse in this model? yes there is a fuse on the board located at the base.
Air Purifiers | Answered on Aug 21, 2020
A powerful vac motor needs lots of air throughput to keep it cool. Some vac motors have a separate air intake and exhaust for cooling air but the majority rely on the same air that passes through the cleaner and sucks up the ash or dirt. These rely on effective filters to keep damaging ash or dirt out of the motor.
While a blocked filter reduces suction and cuts the flow of cooling air, a displaced filter allows ash or dirt into the motor and if early action isn't taken to remedy the situation by cleaning the motor, the life of the motor will be seriously reduced.
The most effective method of motor cleaning after dismantling is by a jet of compressed air...
Air Purifiers | Answered on Aug 01, 2020
HOME IMPROVEMENT STORE PROBABLY IN ELECTRICAL DEPT
Air Purifiers | Answered on May 13, 2020
Pull off the front panel and look at the upper right, you will see two holes. One on top is the size of a pencil, and one below it the size of a dime. Use a paperclip, pen tip, ect and push the reset button in the center of the dime sized hole.
Air Purifiers | Answered on Mar 18, 2020
You would have to pull the ballast transformer out.
Pull the light fitting out.
Fit a new socket.
Run the mains wires that went the ballast transformer to the new socket.
Air Purifiers | Answered on Jan 10, 2020
Support at Guardian
https://www.guardiantechnologies.com/support
From your previous question: the Replace HEPA filter light wont go off.
Note: When you add information to a question, please use the Comment or Edit feature to add it to the same question, rather than opening a new question, because the new one has no link to the older one.
Air Purifiers | Answered on Nov 04, 2019
Check to see if there is a crack in the ceramic plate. If there is any type of disturbance where the metal is glued to it or you don’t have both leads on the metal it will not work
Air Purifiers | Answered on Oct 26, 2019
Where can one get a new bulb ballast for the UV801?
Air Purifiers | Answered on Jul 17, 2019
Electrolux EL6988EZX Oxygen Canister Vacuum Cleaner Logo
2 questions posted
Top Electrolux Air Purifiers Experts
ray gallant
Tom Chichester
Marvin
Marvin
Are you an Electrolux Air Purifier Expert? Answer questions, earn points and help others
View Most Popular
  • Electrolux Air Purifiers
Most Popular Question
need reset power powerhead particular
  • Air Purifiers
