20 Most Recent Movado Valor 0604409 Wrist Watch Questions & Answers
Movado 0604409 watchband adjust
Click on my profile (escapement), then click on Tips and Tricks. There you will find how to remove or add links.. Rate me, please .
4/15/2010 7:20:27 AM • Movado Valor... • Answered on Apr 15, 2010
Wirst band problem
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
7/28/2009 9:50:31 PM • Movado Valor... • Answered on Jul 28, 2009
Size a movado valor 0604409 smaller to fit my wrist.. Anyone??
xxxxxx
7/23/2009 11:21:03 PM • Movado Valor... • Answered on Jul 23, 2009
I'm trying to find out some details about this watch I have
I would ask a jeweller.
1/23/2023 7:49:03 AM • Movado Watches • Answered on Jan 23, 2023
What is my Movado 99.b2.666 watch worth is it authentic?
yes it is fully authentic
6/16/2022 1:47:10 PM • Movado Watches • Answered on Jun 16, 2022
I need to know what this movado watch is worth by serial number
you can check simply by go to movado website
6/15/2022 8:35:26 PM • Movado Watches • Answered on Jun 15, 2022
Where can I get a Movado watch battery in St. Catharines, Ontario.
Hello, Charleen - Take your watch to any nearby jewelry store. They should carry the right battery for your watch and install it as part of the battery purchase. Best wishes.
10/25/2018 5:11:49 PM • Movado Watches • Answered on Oct 25, 2018
Movado Bold promotional Item **********49 . How much it is now ? Thanks !
Hello, An - See my answer to the first time you asked your question about the Movado Bold wristwatch: http://www.fixya.com/answer/answerpageslideview.aspx?ctg=mine&fml=0&brd=1904&thid=27042006 Best wishes.
7/25/2018 4:33:43 PM • Movado Watches • Answered on Jul 25, 2018
Where can I find code's Movado Bold promotional Item ( 885997218849 )? Thanks !
Hello, An -The Movado wrist watch you seem to be asking about may be a men's two tone silver dial watch. It seems the number 885997218849 is the UPC (Universal Product Code) assigned to that model of Movado watch. That model of watch carries the MPN (Manufacturer's Part Number) of 3600431.See the image and information on the Movado Bold wristwatch on this Movado web page:http://www.movado.com/us/en/shop-watches/movado-bold-3600431.htmlThe price (US dollars) on that web page is for a new wristwatch. If you are hoping to resell your watch, I suspect you cannot ask the price of a new watch.Best wishes.
7/25/2018 4:32:50 PM • Movado Watches • Answered on Jul 25, 2018
Movado Valor 0604409 Wrist Watch Logo
5 questions posted
Top Movado Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Movado Watch Expert? Answer questions, earn points and help others
View Most Popular
Movado Watches
  • Movado Watches
Most Popular Question
movado 0604409 watchband adjust
  • Watches
