20 Most Recent Danco 89448A Universal Toilet Tank Lever, Chrome with White Porcelain Handl Questions & Answers
Go to danco web site for correct instructions.
Danco 89448A... | Answered on Jul 28, 2017
Not sure I understand your problem; your handle may be incorrectly installed.
Danco's instructions for replacing this toilet handle can be found here.
Danco 89448A... | Answered on Jan 30, 2014
Sorry to read about your problem, I hope this helps you out.
Nope just the metals will last longer
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Danco 89448A... | Answered on Dec 29, 2010
Readjust the chain or lifting mechanism associated with the flapper to lever connection.
Danco 89448A... | Answered on Nov 26, 2010
You need to hook the chain shorter going to the flapper...the chain is too long...
heatman101
Danco 89448A... | Answered on Sep 04, 2010
It goes on from the inside.
Danco 89448A... | Answered on Apr 21, 2010
lower the float a small amount...make sure flapper is closing completely
Danco 89448A... | Answered on Nov 17, 2009
the chain should have some slack to it being too tight it dose let the flapper sit properly so itll keep running because water is escaping
Danco 89448A... | Answered on Aug 26, 2009
There is two different types of handles. You have a front mount and a side mount. It sounds as though you might have bought one that is for a front mount instead. Also some toilets are brand specific and you are forced to buy OEM parts instead of generic ones. If the handle is metal you could try bending it to get the "swing" you need. But if you do that, you won't be able to take it back for a refund if it doesn't work. Good luck
Danco 89448A... | Answered on Apr 02, 2009
Each manufacturer has a different size shower spout. As long as the fitting doesn't leak, put a flange up against the wall and if needed, use calking to fill the space. This is an aesthetic issue only.
Danco Home | Answered on Oct 01, 2019
Is this a question?
Danco Home | Answered on May 23, 2019
Most of those have a quarter turn plastic pie section at the top of the stem. It reverses for right or left (cold or hot) faucets. Turn off the water supplies, remove the top of the faucet and handles, put the pie shaped sections on opposite sides, reinstall the handles and turn the water supplies back on.
Danco Home | Answered on May 14, 2019
By replacing it
Danco Home | Answered on Jul 08, 2018
The issue might be the tub diverter spout. Most such do not seal well. It is a matter of jiggling the spout knob. It should seal better with a little experimenting.
Danco Home | Answered on Sep 04, 2017
Danco 89448A Universal Toilet Tank Lever, Chrome with White Porcelain Handl Logo
12 questions posted
Top Danco Home Experts
Bill Johnson
Tom Chichester
Are you a Danco Home Expert? Answer questions, earn points and help others
View Most Popular
Danco Home
  • Danco Home
Most Popular Question
after flushing will sound like filling
  • Home
