20 Most Recent Jura Impressa F50 Classic Automatic Coffee Center Questions & Answers
Is a loud noise normal when drawing off hot water for tea?
not if it never did it before when you draw off hot water , there is normally fresh water let in to keep the unit full this cold water hitting the boiling water will produce steam which is allowed to escape hence the noise.
5/25/2015 11:42:47 PM • Jura Impressa... • Answered on May 25, 2015
Jura F50 asks for coffee but it is full of beans?
Hi, I made a video how to fix your Jura step by step, good luck,, http://fixandparts.wix.com/nicknicoloudis#!jura-coffee-machine/c15gy
3/23/2015 11:45:39 AM • Jura Impressa... • Answered on Mar 23, 2015
I have interrupted cleaning process. How can I start it again?
Hi, I made a video how to fix your Jura step by step, good luck,! http://fixandparts.wix.com/nicknicoloudis#!jura-coffee-machine/c15gy
3/23/2015 11:02:04 AM • Jura Impressa... • Answered on Mar 23, 2015
I have the Jura Impressa F50, the machine will no longer function when the coffee grounds conatiner is in place. I have reset the machine several times, have put the container inr\ different positions
on the tip of the tray there are metal contacts that tell the machine that the tray is installed. try cleaning these contacts with steel wool and on the inside of the tray with soapy water and a brush. remove excess water from tray and try
10/29/2014 6:37:23 AM • Jura Impressa... • Answered on Oct 29, 2014
Jura f50 repairing
Probably just needs to be cleaned inside. This is good video for most models. Parts Guru can do it for you if you don't think you're up to it. Or rebuild the brew group for you. https://www.youtube.com/watch?v=mZwkqPeZ0QY
10/23/2014 5:35:01 PM • Jura Impressa... • Answered on Oct 23, 2014
How to fix jura not coffee sign?
It is wanting grounds dropped into the trap door on top. If you open that trap door there is a sensor on the hindge that causes it to expect ground coffee to be dropped in there. This is how you would make a decaf cup with caffeine beans in it or flavored with regular bean in the grinder. Check to make sure the door is closed. It should return to "ready" in about 10 seconds. If not cycle the power by pushing the on/off button or pull the plug. Instructions can be found here: https://www.capresso.com/customer-care-instruction-booklets.shtml
10/23/2014 5:23:43 PM • Jura Impressa... • Answered on Oct 23, 2014
Schaerer SCP is not rinsing correctly
Check the Operating Temperature: Ensure that the machine has reached the correct operating temperature. If it hasn't, the indicator light will be on. Wait until the machine is fully heated before proceeding. Check for Ongoing Programs: If a rinse or cleaning program is currently in progress, the cleaning button may be flashing. Wait for any ongoing programs to complete before trying to brew coffee. Inspect the Brewing Unit: Make sure the brewing unit is properly seated and not obstructed. The brew group should be in the correct position. If the brew group overflows, it could be due to a blockage or misalignment. Remove the brew group, clean it thoroughly, and reinsert it properly. Inspect the Coffee Spout and Drainage Area: Check the coffee spout for any clogs or blockages. Clean it if necessary. Examine the drainage area at the bottom of the machine. If water is running away onto the floor, there may be a leak. Inspect the drip tray and other components for leaks or damage. Refer to the Operating Manual: Consult the operating instructions manual for your Schaerer Coffee Club machine. If the above do not resolve your issues, you may have to contact Schaerer Services.
4/20/2024 9:02:57 PM • Coffee Makers &... • Answered on Apr 20, 2024
Dolce Gusto Coffee Machine. The cold water is working, but nothing coming out of the hot side. No sound, no water, but the cold works fine.
They make a thousand models. It sounds like the heating element has failed. Generic help and videos in the link but these machines need dealer service at regular intervals depending on the complexity of the particular model. https://www.google.com/search?q=Dolce+Gusto+coffee+Machine+no+hot+water ..
4/17/2024 5:11:02 PM • Coffee Makers &... • Answered on Apr 17, 2024
Question about the De Longhi Magnifica coffee machine.
These machines need dealer servicing every 6 to 12 months. They don't tell you that when you buy them. There are some ideas here https://www.google.com/search?q=De+Longhi+Magnifica+warning+triangle ..
4/16/2024 2:41:15 AM • Coffee Makers &... • Answered on Apr 16, 2024
SCHAERER VERISMO 701 AMBIANTE 15 ESPRESSO MACHINE. We have to reset the Verismo 701 continuously even when we have the beans container filled up to the top.
Question edited for clarity. These machine need dealer servicing every 6 to 9 months depending on usage. They don't tell you this when you buy them, but I have been fighting these types of machines for the 9 years before I retired. One place had 2 machines and another has 6. Once machine did 1,200 cups a days and was serviced every month. Airport Business Class Lounges. ..
4/12/2024 5:42:30 AM • Coffee Makers &... • Answered on Apr 12, 2024
2answers
Where can I find Cecilware 3K-GB-LD Cappuccino machine Error Codes, I'm getting ERR 1 on my machine
To find Cecilware 3K-GB-LD Cappuccino machine error codes like "ERR 1," refer to the machine's user manual or technical documentation. Alternatively, contact Cecilware customer support for assistance in diagnosing and resolving the specific error code on your machine.
4/6/2024 8:13:43 PM • Coffee Makers &... • Answered on Apr 06, 2024
Capresso "Perk" Percolator Coffee Maker, 12 Cup. I have 2 percolator model 405.05 and the cord burned out on both i would like to replace the cords
Question edited for a lot more clarity. This is a very standard appliance plug that you can get from Walmart, Home Depot any small appliance store or even Amazon https://ecscoffee.com/products/capresso-12-cup-perculator-405-05 They look to be here https://www.google.com/search?q=percolator+model+405.05+replacement+cord ..
4/3/2024 6:29:51 PM • Coffee Makers &... • Answered on Apr 03, 2024
Looking for instructions for sansui espresso maker. model EM 208. 850 W.
Sasui em 208 coffee machine manual
3/22/2024 3:57:55 PM • Coffee Makers &... • Answered on Mar 22, 2024
2answers
Russell Hobbs Kudos 11418 coffee machine. Does anyone have a manual for it please?
I would go on the Russel Hobbs web site and download one. https://en.russellhobbs.com/user-manuals
3/21/2024 8:56:43 PM • Coffee Makers &... • Answered on Mar 21, 2024
How to repair toggle switches on cuisinart dgb900 coffee maker
You can replace them but unlikely to repair them. The casing will come apart, with some difficulty. Remove the old switch, source an identical new switch and fit it.
3/12/2024 11:29:39 PM • Coffee Makers &... • Answered on Mar 12, 2024
Why Jura ENA 1 wont turn on?
You simply have power supply board problem(PSU)
2/29/2024 6:17:17 AM • Coffee Makers &... • Answered on Feb 29, 2024
Jura Impressa F50 Classic Automatic Coffee Center Logo
10 questions posted
Top Jura Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Kolbrun...
Are you a Jura Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Jura Coffee Makers & Espresso...
  • Jura Coffee Makers & Espresso...
Most Popular Question
  • Coffee Makers & Espresso Machines
