20 Most Recent
Taylor 91756 Wireless Thermometer With Indoor/outdoor Humidity & Clock Questions & Answers
How to disable the alarm function on a Taylor weather station type wec-1502 ?
To disable the alarm function on your Taylor weather station type WEC-1502, follow these steps:
- Press and hold the "ALARM" button on the top of the unit until the alarm icon disappears from the display.
- Release the "ALARM" button.
- Press the "MODE" button on the top of the unit until the display shows the "CLOCK" mode.
- Press and hold the "ALARM" button again until the alarm icon disappears from the display.
Your Taylor weather station should now be set without the alarm function.
My Taylor we 1502 is showing HH in the outside relative indicator. How do I get it to recognize the outside relative humidity %? Thanks
If the outside temperature is currently displayed, there may not be anything wrong with the we 1502 sensor. The HH indicates that the outside relative humidity is above 95%; that is a limit of the sensor's detection/accuracy range. You could try moving your we 1502 sensor to a dryer area where it isn't exposed to rain/other falling water or wait until things dry out.
I hope this helps. Please add a comment with the model for the base of your weather system for more information. The HH message applies to most Taylor weather systems. The manual for the Weather Guide Indoor/Outdor 1731 system is available here: http://ecx.images-amazon.com/images/I/71QBC5RdcNS.pdf .
How to change time on Taylor Precision Products Wireless Digital Indoor/Outdoor Thermometer FCC ID WEC 1502
The Clock display is located at the top of the base unit's LCD screen. The clock has alarm and snooze functions.
A) Clock Setting
1. Press and hold the "SET" button on the back of the base unit for 3 seconds to enter Clock Setting Mode. The year digits flash in place of the clock digits.
2. Press the "+" or "-" button to change the year. Press "SET" to confirm. The month digits flash.
3. Press the "+" or "-" button to change the month. Press "SET" to confirm. The date digits flash.
4. Press the "+" or "-" button to change the date. Press "SET" to confirm. The Day/Month ("D M") or Month/Day
("M D") selection flashes.
5. Press the "+" or "-" button to toggle between Day/Month and Month/Day format. Press "SET" to confirm. A language selection flashes under the "DAY" icon to the left of the clock digits.
6. Press the "+" or "-" button to toggle between language selections*. Press "SET" to confirm the displayed language. Time zone offset digits flash in place of the clock.
7. Press the "+" or "-" button until the correct time zone offset** appears (-12 to +12). Press "SET to confirm the displayed time zone offset. "12 Hr" or "24 Hr" flashes.
8. Press the "+" or "-" button to toggle between 12 and 24 hour clock mode. Press "SET" to confirm.
The hour and minute digits reappear. The hour digits flash.
9. Press the "+" or "-" button to change the hours. Press "SET" to confirm. The minute digits flash.
10. Press the "+" or "-" button to change the minutes. Press "SET" to confirm. The hour and minute digits stop flashing. The clock is set.
Replaced batteries, outsid temp. does not display
Base Station Battery Installation
·Remove the printed vinyl label from the LCD screen of the base station
·Position the remote sensor near the base station
·Open the battery compartment at the back of the base station and insert (2) AA batteries according to the polarity markings. Replace the battery compartment cover.
·Within a short time the RF signal icon (located to the left of the outdoor temperature channel indicator) will start flashing. This indicates that the base station is ready to pick up the RF outdoor temperature signal from the remote sensor. It will continue to flash for 3 minutes or until the signal from the remote sensor is detected.
Register the Remote Sensor
·Open the battery compartment at the back of the remote sensor and slide the channel selector switch to your desired channel. For the first remote you may select any channel, for additional remotes select any unused channel
·Insert (2) AAA batteries according to the polarity markings. Be sure to install the batteries in the remote within the time that the RF signal icon is flashing on the base station.
1541 WeatherGuide Wireless Weather Forecaster with Barometer
