20 Most Recent
Union Pegasus F1228100PBV Series 5000 Shower Only Faucet, Polished Brass Questions & Answers
Where is the escucheon located
this is the plate behind the handle or it is the plate that is on the shower head arm itself its the little circle plate that is againts the wall to hide the hole
I have a pegasus thermostatic
I have a similar problem in a house I just moved into. It's clearly not an issue with the temperature settings because I adjusted those and it hasn't fixed the problem. Pressure is low and it's only hot water, which leads me to believe the cold water isn't making it to the faucet for some reason. Have you figured out a solution? I'm searching all over and can't find anything. It's maddening. Thanks.Bob
I cannot get the water hot enough and maitain the
pegasus is a home depot product u need to adjust ur anti scald setting the valve is shipped in cold position it should have a red and blue plastic clips that go over the grooved thing call pegasus customer service at 1888 328-2383 they should be able to assist u with ur problem if u need parts or how to adjust the anti scald system
Have a pegasus shower single valve ..cannot
when it is sold the anti-scold is set at cold to protect the buyer -the piece with the groves on it is the stem their should be two plastic clips a red and blue that slid over it these clips are the adjustment -also give pegasus a call they have an 800 number to assist u or home depot the carry the brand
Pegasus schematics
there is another plumbing place called furgouson i think thats how you spell it,check my spelling,lol good luck.if they don't have it they most times can order it for you.
