20 Most Recent Leeson 110912.00 1 HP 208-230/460V C6T17FK6G 3-Phase General Purpose Compressor Duty Motor Questions & Answers
Use a hammer ........
Air Tools &... | Answered on Apr 29, 2020
make sure the safety valves not open. and the drain
Air Tools &... | Answered on Apr 23, 2020
Actually this could become dangerous. When dry latex paint can char or burn.
Although it could be expensive, I would recommend calling a local heating contractor and have him check it out. If it's near the combustion chamber, it will burn; at very least causing smoke and fumes.
Get a professional opinion.
There should be a wiring diagram on the motor name plate. If it isn't there, there isn't much anyone can do, there are literally hundreds of different wiring methods for single phase motors.
Air Tools &... | Answered on Apr 21, 2020
chech for power and test start capacitors
Air Tools &... | Answered on Apr 04, 2020
a bad temperature or pressure sensor
Air Tools &... | Answered on Mar 27, 2020
With hardware issues, it is best to post the brand and model along with the question. That said, you may try a Google search for a YouTube video if you include the aforementioned description of the gun. Here is an example: https://www.youtube.com/watch?v=yg1zx61vlfA
I have no way of evaluating the quality of the repair advice in the videos and can only suggest you consult a professional gunsmith. I certainly wouldn't care to be even partially responsible for any consequent accidents resulting from faulty repair. But if you are knowledgeable about the particular item,you might consult a hobbyist group for preliminary advice. It might give you at least a clue as to how costly or difficult the repair might be.
Air Tools &... | Answered on Mar 21, 2020
Is the smoke white, blueish, or black? White smoke is either raw fuel from a misfire or antifreeze from a bad head gasket, cracked head, etc. Blueish smoke is engine oil being burned which is a sign of worn/cracked rings. Black smoke is too much fuel being burned, bad timing, or maladjusted valves.
Air Tools &... | Answered on Mar 18, 2020
On a 375 h s#201202020049 change the element in the compressor crank and run for 10 minutes good are and then shuts off and it won't crank back turns over but won't start
Air Tools &... | Answered on Mar 16, 2020
IF you don't have a special meter, that costs more than the capacitor, just replace it. The meter is called an ESR meter and they are $$
Air Tools &... | Answered on Mar 11, 2020
I am currently obtaining information on roof paints and I can share what I have found out
roof restorers use a membrane paint rather than an ordinary acrylic paint or enamel paint as it is the most resilient paint for the application
IT is applied at a pressure of 3000 psi from a special gun and paint pump, cannot be rollered or brushed and goes on to a thickness of 150 microns ( around .120")
the cost is around $400.00 for 10 litres which covers around 10 sq meters ( 3ftx3ft)
acrylic can be sprayed or rollered or brushed on and is good for about 10-15 years depending on the roof to start with (thickness around .030" --same as car paint job)
costs around $180.00 for 15 lts and covers 14-16 sq meters
namel should be avoided as it does not have the capacity to expand or contract with temperature changes
professional roof restorers will repair any problems , clean the roof off and then apply the membrane paint as it gives a good quality result
other than that I would talk with paint suppliers as they have the same membrane paint that the professionals use and get ideas as to the way to go.
Air Tools &... | Answered on Mar 04, 2020
MIGHT NEED A NEW PRESSURE SWITCH
When a service warning occurs, contact your local service representative. Service engineer will master reset the warning after completing the service work.
Air Tools &... | Answered on Feb 26, 2020
It would have been helpful if you had mentioned which breaker is tripping?
Most modern mains electrical circuits are protected by at least two breakers - an MCB and either an ELCB or RCD.
The micro circuit breaker replaces the old fashioned fuse and does the same job - if the MCB trips, the appliance is consuming too much current; perhaps indicating shorted turns in the motor...
If the RCD or ELCB trips it indicates current is leaking into the ground circuit; indicating perhaps damp or water ingress or an insulation breakdown...
Air Tools &... | Answered on Feb 25, 2020
so without having a meter on this my first idea is the motor starting contact relay saddle mounted contacts either have a wire loose, broken, or the contact itself has failed and not sending the feedback to the plc that the motor starter has in fact closed to start the motor, one way to trouble shoot this is to manually close the motor starter and ohm out that particular contact set to see if this shows it closed. do this with the power off as when you close this manually it will try to start the motor. ohi it before and after u manually close that starter relay.
Air Tools &... | Answered on Feb 19, 2020
Leeson 110912.00 1 HP 208-230/460V C6T17FK6G 3-Phase General Purpose Compressor Duty Motor Logo
0 questions posted
Top Leeson Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Leeson Air Tool and Compressor Expert? Answer questions, earn points and help others
View Most Popular
  • Leeson Air Tools & Compressors
Most Popular Question
campbell air compress build up presser
  • Air Tools & Compressors
