20 Most Recent
Generac Guardian 200 Amp Transfer Switch NEMA 3R Questions & Answers
What other causes can prevent
Not sure what causes you have eliminated....already.... but there is a wire that is hooked on the ulity side of the switch that goes to a sensing coil and then switches it back... the problem would need to be that the wire is not hooked right or is corroded or the sesing part is not working properly.
There is really nothing else that it can be...
My experience has been that Generac tech support is top notch, and a phone call to them probably will get to the bottom of your problem rather quickly... they also will be able to speed you the exact part that you need....
heatman101
I have a 20KW Generac
justlaffs,
Follow the instructions in the diagram in the manual. You cannot have a complete circuit with the neutral disconnected and the unit would be dangerous as the external metal surfaces could be at 120 vac and be a shock hazard. I do not understand why you have two different hookup instructions but you definitely need to hook all three wires up, black, white and green.
Thanks for using FixYa and for the great rating.
hardrocko
Generac 0058711, 10KW Generator. How to reflash home standby 10kW Generac generator model number 0058711 please.
That is a full home back-up unit. You need dealer support. Contact them direct. There is nothing online about re-flashing.
Support For Your 0058711
Generac Power Systems
https://www.generac.com > product-support-details
File Type
Manual (PDF)
Item Number
Langu...
Emissions Warranty Statement
WARRANTY STATEMENT EMSN E P3
0J3335
EN
Exploded View (Control Panel)
EV CONTROL PANEL ? HSB
0J3707
EN
Exploded View (Enclosure)
EV ENCLOSURE HSB 2011
0J4730
EN
View 29 more rows
Product Manuals
https://www.generac.com > product-support-lookup
Model Number: G0058711 Description: 10KW/530 GUARD+12C T/SW ... Parts Manual / EV (Unit), EV GENERATOR - HSB, 0J3899, EN.
Find My Manual, Parts List, and Product Support - ...
https://www.generac.com > service-support > product-...
Enter your model or serial number to find Generac specifications, manuals, parts lists, FAQs, how-to videos, and more for your product.
6/11/2023 3:58:22 PM •
Generac...
Answered
on Jun 11, 2023
Generac generator won't turn off in automatic
It is possibly a transfer switch issue, not the generator control board. Have an electrican kill utility power, let it start and run, then disconnect the sensing wires in the ATS. If it stops problem is ATS
1/11/2023 2:04:47 AM •
Generac...
Answered
on Jan 11, 2023
Generac 16kw generator starts on its own in automatic mode
Check the wiring from the utility through to the autostart control.; make sure all connections are solid and the wire itself is in good condition. New wire is no guarantee, several times I've had wire with a break somewhere in the reel. A non-contact voltage detector may helpful; start at the controller end, go to the other end of the wire, and see where you lose the voltage detect. It will detect voltage up to the break if you can keep the detector close enough to the wire.
7/31/2022 10:59:51 PM •
Generac...
Answered
on Jul 31, 2022
I have a Generac 5000 Watt Power Plus Mod-00413-0
Does this have an oil filter and if so wich one do i need ?!?
Regarding the advice about "Flashing" a generator.
Do you people even know what that means?
What you are doing is messing with the capacitor that is part of the voltage conversion. Likely you are burning any shorts out of the capacitor. Has noting to do with the fields or coils or rectifier.
So if you are having issues then test the capacitor and replace it.
Try your flashing and see if you don't fry the rectifier.
It amazes me that people will blindly follow something they don't understand "hoping" that something good will happen.
But if a new generator is what you want then give your old one away instead of trashing it.
12/15/2021 6:43:11 PM •
Generac...
Answered
on Dec 15, 2021
My 32KW Generac RG03224KNA's screen won't come on.
The manual does not specify a minimum voltage for the battery. It merely defers to battery manufacturer specifications.
Measure the battery voltage with a DMM. A fully charged battery will be 12.5 to 12.7 volts. Any reading less than 12.25 will likely be problematic for the generator system. Remove battery and have it load tested or replace with a known good or new battery.
9/17/2021 8:32:47 PM •
Generac...
Answered
on Sep 17, 2021
