20 Most Recent Jacuzzi Signa Whirlpool Tub B540 Questions & Answers
This is is a problem that develops over time. The center of the air button can get calcium built up and the close tolerances of the button and the inside of the button body will begin to stick.
Take some soft emery cloth and run around the inside of the button bosy and the outside of the button then reinstall and see if that will prevent the button from sticking in the down position.
Rod
US Parts Center
888-521-6183
Jacuzzi Signa... | Answered on Mar 26, 2013
If it is a air button that pushes in and comes back up, there is a good chance that the switch (which is mounted on the pump/motor) is bad. If the switch is a touch button on a key pad, the problem is in the control box for the pump/motor.
Jacuzzi Signa... | Answered on Sep 05, 2009
Several things can cause this problem- if you post a picture of the inside of the tank so we can have a good look at how the fill/stop mechanism operates that would be great. We could more than likely identify some type of problem and solution. Not all flush/fill mechanisms are not the same but thats surely where your problem is UNLESS its in your water lines. I would love to help you just please provide photos and as much information as you can.
Mr.Mike
Jacuzzi Home | Answered on May 20, 2020
Contact the Dealer and seek qualified tech service. Risk of electric shock/***** You should not take the risk but have a QUALIFIED SERVICEPERSON perform the work.
Jacuzzi Home | Answered on Jun 29, 2019
There may be a video but you should be able to tell by looking at it too
big screw under tank holds valve on
toilet-dual-steelwire-drive-flush-valve-a2312-p2302-[1]-zgzkf31tgqefbd1nldh0nf0r-3-1.jpg
see:
https://reviewmotors.co/jacuzzi-dual-flush-toilet-repair-parts
Jacuzzi Home | Answered on Jun 14, 2019
If there is power to the unit, most likely it will need to be replaced. Check for reset button, and check the fuses before replacing the unit.
Jacuzzi Home | Answered on May 23, 2019
Should be one on the motor and also check to see if there is a GFCi somewhere too. Could be around where the jacuzzi switch is.
Jacuzzi Home | Answered on Feb 10, 2019
the motor could be seased, can you get to back of motor to see if it's spinning
Jacuzzi Home | Answered on Sep 23, 2018
Jacuzzi Signa Whirlpool Tub B540 Logo
5 questions posted
Top Jacuzzi Home Experts
Mike
john h
Bill Johnson
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
View Most Popular
Jacuzzi Home
  • Jacuzzi Home
Most Popular Question
jacuzzi air off button tub jams in when
  • Home
