20 Most Recent Jacuzzi Nova Whirlpool Tub H532 Questions & Answers
Sounds like you may have a circuit that is bad in the control box under the tub.
Very unusual for that type of issue unless there is a problem on the circuitry.
Call a technician to have them trouble shoot it for you. It may need to be replaced. Those are not usually an item that is fixed.
Rod
US Parts Center
Jacuzzi Nova... | Answered on Feb 26, 2014
Power switch appears to have a short in it. See the dealer you purchased the tub from and have them install the part.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/don_e04c7d10037aa2ce
Jacuzzi Nova... | Answered on Apr 04, 2011
Several things can cause this problem- if you post a picture of the inside of the tank so we can have a good look at how the fill/stop mechanism operates that would be great. We could more than likely identify some type of problem and solution. Not all flush/fill mechanisms are not the same but thats surely where your problem is UNLESS its in your water lines. I would love to help you just please provide photos and as much information as you can.
Mr.Mike
Jacuzzi Home | Answered on May 20, 2020
Contact the Dealer and seek qualified tech service. Risk of electric shock/***** You should not take the risk but have a QUALIFIED SERVICEPERSON perform the work.
Jacuzzi Home | Answered on Jun 29, 2019
There may be a video but you should be able to tell by looking at it too
big screw under tank holds valve on
toilet-dual-steelwire-drive-flush-valve-a2312-p2302-[1]-zgzkf31tgqefbd1nldh0nf0r-3-1.jpg
see:
https://reviewmotors.co/jacuzzi-dual-flush-toilet-repair-parts
Jacuzzi Home | Answered on Jun 14, 2019
If there is power to the unit, most likely it will need to be replaced. Check for reset button, and check the fuses before replacing the unit.
Jacuzzi Home | Answered on May 23, 2019
Should be one on the motor and also check to see if there is a GFCi somewhere too. Could be around where the jacuzzi switch is.
Jacuzzi Home | Answered on Feb 10, 2019
try moving by hand they are calcified
Jacuzzi Home | Answered on Nov 04, 2018
the motor could be seased, can you get to back of motor to see if it's spinning
Jacuzzi Home | Answered on Sep 23, 2018
Jacuzzi Nova Whirlpool Tub H532 Logo
2 questions posted
Top Jacuzzi Home Experts
Mike
john h
Bill Johnson
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
View Most Popular
Jacuzzi Home
  • Jacuzzi Home
Most Popular Question
lasco bubbler massage tub
  • Home
