20 Most Recent Orvis 82KG6000 Questions & Answers
How to set pocket watch
Hi John, There are several possiblitites depending on the watch you have. If it is a battery watch you set it like most modern watches by pulling the pendant and the hands should move. If it is a vintage watch it may set the same way. If gentle pulling the crown does not work try this. Your watch may be a lever set watch. This requires removing the crystal of your watch will be screwed on. If it doesn't loosen easily try putting the watch between your palms and twist. Once the crystal and bezel loosen remove it and set it aside. Now look near the 2 o'clock position. A lever set watch will have a small metal piece sticking up that is designed to be hooked with your fingernail and pulled out. When in the out position your watch will now be in the setting position and your hands will move when you rotate the crown. After setting push the lever back in and you will now be in the winding position. Replace the crystal and carefully screw it down but not too tightly. There are other systems but I am guessing this will cover your watch. Merry Christmas
12/24/2011 5:49:01 PM • Orvis 82KG6000 • Answered on Dec 24, 2011
How do I turn the alarm on?
Need more info ,make and model # and re post with that question and info. press the helpful button
1/22/2016 9:32:04 PM • Orvis Watches • Answered on Jan 22, 2016
IT IS AN ORVIS AUTOMATIC
Thank you for contacting FixYa.
When you first receive your automatic watch, you must give the watch an initial pre-wind. If you wear it everyday, it will continue to wind itself on your wrist when you move around and walk. If you stop wearing it for more than approximately 2 days, the watch will need to be reset, but will then automatically wind itself once you start wearing it again. The disadvantage to this is pretty clear. Your watch does not t keep time if you do not wear it constantly. The advantages are that you will never have to replace a battery, the watch keeps great time when it is running, and most of all, this type of movement is exactly what the originals use! If your Automatic is losing or gaining time in a 24-hour period the watch needs to be adjusted. All of our automatics have an adjustment screw on the movement just like the originals. Any local jeweler can service these watches.
Best regards! Jewel
8/25/2010 11:45:18 PM • Orvis Watches • Answered on Aug 25, 2010
Swiss Legend Monte Carlo watch. What size battery do I need for my watch please?
Question edited for clarity. Question moved from Misc to Watches. https://www.fixya.com/support/r27181038-changing_watch_batteries How do I know what size battery for my watch? Sometimes this is printed on the back of the watch - as with some Timex watches - but in many cases you will need to open your watch case to see the code on the battery. The code can take various forms such as: CR1216. No one every tells battery types, because they vary. The answer is "the one that came out of it". https://www.google.com/search?q=Swiss+legend+Monte+Carlo+watch+battery ..
3/20/2023 8:25:27 PM • Watches • Answered Yesterday
How to change to show right day of week
Impossible to answer. On WHAT!!! All questions need FULL 'make model (what it is)'. Google make model manual Normally on that type of device you have to set the YEAR, and then the MONTH like on my Weather Station Indoor Unit.. ..
3/19/2023 11:37:13 PM • Watches • Answered 2 days ago
Time not set properly in my watch lasika w-f62
To set the time on your Lasika W-F62 watch, please follow these steps:
  1. Press the mode button on your watch until you reach the time-setting mode.
  2. Press and hold the "Set" button until the hour digits flash.
  3. Use the "Adjust" button to set the correct hour.
  4. Press the "Set" button again to move to the minute digits, which will also be flashing.
  5. Use the "Adjust" button to set the correct minute.
  6. Press the "Set" button again to confirm the time and exit the setting mode.
If you have any trouble setting the time on your watch or if it doesn't seem to be working properly, please consult the instruction manual that came with your watch or contact the manufacturer for further assistance.
3/19/2023 11:07:59 AM • Watches • Answered 3 days ago
My dango watch second hand stops some time
If your Dango watch's second hand stops intermittently, there are a few things that could be causing the issue. Here are some possible reasons and solutions:
1. Low Battery: If the battery in your watch is running low, it could cause the second hand to stop. You may need to replace the battery in your watch. Check your watch's manual or take it to a watch repair shop to have the battery replaced.
2. Dirt or Debris: Dirt or debris can get inside your watch and cause the gears to stop moving properly. If this is the case, you may need to have your watch cleaned and serviced by a professional watch repair person.
3. Loose Second Hand: If the second hand on your watch is loose, it could cause it to stop intermittently. A loose second hand can be caused by a damaged pinion or cannon pinion. You may need to take your watch to a professional watch repair person to have it fixed.
4. Magnetic Interference: Magnetic fields can interfere with the movement of the gears inside a watch, causing it to stop or run erratically. If you have been around strong magnets or electronic devices, it could be causing the issue. Try moving your watch away from these devices to see if that helps.
5. Mechanical Issue: There may be a mechanical issue with your watch's movement that is causing the second hand to stop. This can be caused by a worn out gear or other component. You may need to take your watch to a professional watch repair person to have it fixed.
3/14/2023 2:27:20 AM • Watches • Answered on Mar 14, 2023
2answers
Need instructions for a solar lithium watch t.g.h.K. aww 91-754
GOOGLE THE PART YOU NEED
3/12/2023 6:10:20 AM • Watches • Answered on Mar 12, 2023
What is 'R O' on the box of a watch.
It means it is a copy of a 'Rolex Oyster' without actually saying it. https://www.google.com/search?q=What+is+r+o+in+a+box+on+watch ..
3/1/2023 6:14:52 AM • Watches • Answered on Mar 01, 2023
User's manual for Studer Schild Walton Chronograph Mens Watch
You can ask for it here... http://www.studerschild.com/contact-support.php?pageID=4
2/19/2023 6:29:50 AM • Watches • Answered on Feb 19, 2023
Looking for instructions for a CHISEL 5829702 watch
Unfortunately, that make and model combination don't exist. Some watches come in bulk from China. All good watches should come with an instruction sheet. https://www.google.com/search?q=CHISEL+5829702 All watches are the same and are governed by how many buttons they have, 2, 3, or 4. https://www.google.com/search?q=fossil+4+button+watch+manual ..
2/17/2023 2:37:51 AM • Watches • Answered on Feb 17, 2023
Ingersoll Ottawa in16198k. I just need an owners manual for this watch please?
Question edited for clarity and spelling of Ottawa, capital of the Province of Ontario. Question moved from Ingersoll Rand Compressors to Watches. The watch doesn't exist. Are you by any chance in South Africa and this watch was a promotion item from Ingersoll Rand? https://www.google.com/search?q=ingersoll+ottawa+in16198k You can find generic instructions based on how many buttons it has, 3, 4, or 5. https://www.google.com/search?q=3%2C+4%2C+or+5+button+watch+manual ..
2/15/2023 5:51:23 AM • Watches • Answered on Feb 15, 2023
My watch not working how to setup
  1. Check the battery: Before attempting to set up your watch, make sure that the battery has not run down. If the battery is dead, you will need to have it replaced by a professional watchmaker or authorized Breitling service center.
  2. Wind the watch: If the battery is not dead, you may need to wind the watch to get it started. Most Breitling watches have a self-winding mechanism, but if it has not been worn for a long time, it may need to be manually wound.
  3. Set the time: Once the watch is running, you can set the time by pulling out the crown (the knob on the side of the watch) and turning it until the hands are set to the correct time. Push the crown back in when the time is set.
  4. Set the date: If your watch has a date function, you can set the date by pulling the crown out to the second position and turning it until the date changes. Push the crown back in when the date is set.
  5. Synchronize the time: If your watch has a chronograph function (stopwatch), you may need to synchronize the time to ensure that it is accurate. You can do this by starting the chronograph and waiting for it to complete a full revolution.
2/12/2023 2:23:55 AM • Watches • Answered on Feb 12, 2023
I need a manual for a 'Smael' brand Dual time watch.
Buy a new one for $15 and get the manual. :>D This link gives the button functions. https://www.aliexpress.com/item/32779408249.html Dawn Soriano. Top right button for 12/24 hour. Probably 'press and hold'. 12/24 HOUR FORMAT SELECTABLE (PRESS C) Alarm Mode ALARM MODE: PRESS "B" KEY ONCE TO ENTER TO ALARM MODE, PRESS "C" KEY TO SELECT CHIME/ALARM. PRESS "D" KEY TO FLASH HOUR. PRESS "C" KEY TO ADJUST. WILL FLASH MINUTES. PRESS "C" KEY TO ADJUST MINUTES. PRESS "D" KEY TO SET. PRESS "B" KEY TO RETURN TO MAIN SCREEN WHEN AN ALARM SOUNDS, PRESS THE "B" KEY TO STOP THE ALARM AND START SNOOZE FUNCTION. IT WILL ALARM AGAIN AFTER 5 MINUTES. PRESS THE "C" OR "D" KEY TO STOP THE ALARM. ALARM WILL STOP AUTOMATCALLY AFTER 20 SECONDS ? TO HAVE YOUR WATCH SOUND AT EVERY HOUR, PRESS "B" KEY ONCE. PRESS "C" KEY TILL ALARM BELL APPEARS. TO DISARM, PRESS "C" KEY TILL THE BELL IS BLANK. https://www.dxl.com/media/content/pdf/98776_instructions.pdf https://www.google.com/search?q=smael+dual+time+watch+instructions ..
2/7/2023 11:09:33 PM • Watches • Answered on Feb 07, 2023
Battery for Ripcurl Tide watch.
Take out the guesswork and they have Loupes. https://www.fixya.com/support/r27181038-changing_watch_batteries ..
2/7/2023 11:04:06 PM • Watches • Answered on Feb 07, 2023
Hello. After replacing the battery, how to reset Miota 6u50
google can not find what CAR is a MIOTA? NOR ANY 6U50 what is this thing tell what it does first. car or truck.? in what country and year car
2/5/2023 12:16:14 PM • Watches • Answered on Feb 05, 2023
Orvis 82KG6000 Logo
1 questions posted
Top Orvis Watches Experts
Marvin
Marvin
john h
Are you an Orvis Watch Expert? Answer questions, earn points and help others
View Most Popular
Orvis Watches
  • Orvis Watches
Most Popular Question
set pocket watch
  • Watches
